Transmission Cooler Line Relocation Bracket - Pic?
Hey folks. Would anyone happen to have a picture of the "Kooks Transmission Cooler Line Relocation Bracket"? I've searched high and low and reached out to Kooks as well - I can't find a single image of the sucker.
There's a 5-week minimum turn-around on the part and I have a set of American Racing Headers (1 7/8) with clearance issues that would likely benefit from this little gem.
Any info (mainly pictures) would be incredibly beneficial. Thanks in advance.
It’s just a piece of flat aluminum bar/plate, about 3/16” thick by about 3/4” - 1” wide and say, 4” long, with a couple of bends in the middle to make it into a bracket that pushes your ATF cooler lines up slightly away from your right side header collector. Doesn’t work all that great either, to be honest, since the cooler lines are very stiff and are clamped to the front of the torque tube and have a bend that puts them right against the header. I’ll see if I can shove my arm under the car and take a picture of it later.
