C6 ls2 ticking noise
Old Aug 17, 2020 | 08:32 PM
Ls2 Noob's Avatar
Ls2 Noob
Default C6 ls2 ticking noise
Started the car today after it’s been sitting for a day and started to hear a slight ticking noise. Let the car sit for an hour and then restarted it again but didn’t hear the tick anymore or during higher rpms. Did a cam and head swap with new lifters about 1k miles ago with the engine having 83k on it. So now I’m kinda stuck on what I should do. Should I check the rocker arms make sure they aren’t loose? Maybe a lifter went bad already? Or don’t worry about it unless it comes back? Not to familiar with engines so any advice would help. Thanks in advance! Also added a link
File Type: mov
Old Aug 18, 2020 | 07:22 PM
grpweld's Avatar
grpweld
That sounds like more than ticking, can you pinpoint or tell which side?
Old Aug 18, 2020 | 07:46 PM
ClothSeats's Avatar
ClothSeats
When you installed your new lifters, did you also install new GM lifter trays purchased at a GM parts department? If you installed new lifter trays purchased from an auto parts store, they may be of inferior quality and allow the lifters to turn. Even the original, used, GM lifter trays are better than new aftermarket knockoffs. The lifter trays are supposed to keep the lifters from turning. Once there is clearance in the trays and the lifters are allowed to turn, they don't run true against the cam and start to skid across the cam face. Then, the edges of the roller on the lifter start to chip out. Both the lifter and cam will be shot in short order. If allowed to continue, the roller on the lifter will fall apart and the lifter bore will be damaged, at which point your block is shot. I can't say for sure that this is what is causing the ticking noise in your case. A lot depends on how you handled the lifter tray situation during your rebuild at 83,000 miles. I hope it is something else. Anyway, here is a video that demonstrates what I was talking about:
Old Aug 18, 2020 | 08:36 PM
Ls2 Noob's Avatar
Ls2 Noob
LS Lifter Trays
we used the old gm lifter trays.
Old Aug 18, 2020 | 08:37 PM
Ls2 Noob's Avatar
Ls2 Noob
sounds to me it’s coming from the passenger side
Old Aug 19, 2020 | 12:01 AM
grpweld's Avatar
grpweld
That's good as the passenger side valve cover is easier to remove, pull it & inspect the rockers & springs
Old Aug 26, 2020 | 11:49 AM
RobJoy's Avatar
RobJoy
Had an intermittent lifter tick on start up several years ago and took it to the Corvette mechanic at the Chevy dealer. He said it's not uncommon and to not worry about it unless it does it all the time. Said LS engines will do this.
Old Aug 26, 2020 | 11:43 PM
DSOMC6's Avatar
DSOMC6
Any abnormal oil pressure fluctuations at idle or while driving?
When my lifter gave-out it immediately sounded like marbles rattlingly around in a coffee can...there was no previous ticking, knocking etc.
Other than sound, the oil pressure was fluctuating up-and-down madly (for obvious reasons).
To C6 ls2 ticking noise
