Melling Oil Pumps
Old Aug 27, 2020 | 05:17 PM
JSracing's Avatar
JSracing
Default Melling Oil Pumps
Has anyone had any issues with a melling hi volume Pump sucking the OEM ( obviously wet sump ) Pan dry?
Old Aug 28, 2020 | 08:22 AM
jonjoy's Avatar
jonjoy
You do not need it a standard Melling replacement for stock is fine
Old Aug 28, 2020 | 12:20 PM
grinder11's Avatar
grinder11
Default Not needed....
This response doesn't answer the OP question, so please allow me. I've had a high volume Melling oil pump in 2 different engines. I believe there are 2 numbers, 10295, and 10296? Don't remember which is which. The high volume body and gerotor assembly is wider/thicker by around 3/16"-1/4" when compared to standard. I currently am running a wet sump LS7 in a C5. The block has piston oil squirters, so the demand for oil is high. I have run this pump in two different 427s, and NEVER pumped the pan dry. Of course I've never run at Bonneville or any airport top speed contest, either. Mainly because of the oil squirters, I did space the high volume oil pump relief spring about 1/8"-3/16" stiffer than stock. I've yet to pump the pan dry at the 617hp@crank level. OP, why do you believe you're pumping the pan dry?
Old Aug 28, 2020 | 12:27 PM
jonjoy's Avatar
jonjoy
In your application would not a high volume pump been the choice as opposed to high pressure? My guess is that OP doesn't have a clue about oil pumps period. Just something he's read or something that was said by a friend of his sitting around the car in the garage
Old Aug 28, 2020 | 04:46 PM
JSracing's Avatar
JSracing
I do NOT have one yet. I was looking into getting one as I am putting in a cam and had a friend of mine warn me that they can pump the pan dry. I have my doubts on this because ive never heard of this issue b4 with the Pump.
Old Aug 28, 2020 | 04:49 PM
JSracing's Avatar
JSracing
1/2 true. I don't have a clue about these particular pumps on LS motors. I run a dry sump peterson 4 stage on a blown alky tim mcamis top sportsman car. so you are half right. Other wise I know a pretty good bit about oil scavenging on Hi Po engines. this is a particular situation though. Cant compare apples to oranges.
Old Aug 28, 2020 | 04:59 PM
JSracing's Avatar
JSracing
actually its not even half true, all you got right was the friend part. and his car is a 64 Impala with an LS " iron block" single turbo done himself and tuned himself with HP tuners, so I listen to him on LS stuff. Its heavy but runs a solid low 11's with MT Et streets, it needs better tires.
I did learn one thing here, you arent that good at guessing.
Best thing i should have done in the first place is just call mellings tech line. thanks everyone else.
To Melling Oil Pumps
