2005 traction control question
Old Aug 31, 2020 | 11:53 PM
Bkings's Avatar
Bkings
Default 2005 traction control question
I've searched but I have not found a clear answer.
2005 with 6 speed.
Pressing the the TC button turns it TC off. Pressing it again turns it on. Is there a competition mode where both TC and AH are off?
I've tried pressing it again within 5 seconds and I've tried pressing and holding it. And all the combinations.
All I get is TC on and off.
Old Sep 1, 2020 | 05:56 AM
Texan79423's Avatar
Texan79423
My 05 press once TC off, Press again Comp mode on, Press again TC and active handling on, Press and hold all off. On mine turn all off and *** end will really kik out.
Old Sep 1, 2020 | 09:00 AM
Bkings's Avatar
Bkings
That's what I thought should happen after reading up on it.
Old Sep 2, 2020 | 05:08 PM
grpweld's Avatar
grpweld
Hopefully not when you're trying to go straight
Old Sep 2, 2020 | 05:54 PM
Bkings's Avatar
Bkings
Just checked again. My TC only turns on and off.
Old Sep 3, 2020 | 12:24 PM
Texan79423's Avatar
Texan79423
That's not right. I have a Z51 I assume they are the same on all 05's, Try pushing on then two quick taps for all on
Old Sep 4, 2020 | 01:51 AM
Dano523's Avatar
Dano523
Pull codes, since there is something going on that is keeping you out of comp mode, off all mode.
Old Oct 2, 2020 | 05:33 PM
Bkings's Avatar
Bkings
I pulled the codes. There were none present. Unless they're deeper than my scanner can read.
any ideas?
Old Oct 2, 2020 | 06:03 PM
Dano523's Avatar
Dano523
any ideas?
Need to pull codes with a Tech II, or some other scanner that can get down to those code levels. Hence basic scanner will not pull codes at either the body level, or the ABS level.
To 2005 traction control question
