Info and recommendations
I have a 2008 Z06, 28xxx miles.
1-- It has the apparently common issue of oil leaking from the pan gasket. I have the part from GM. Is there anything else needed to go along with it, other than the obvious oil and filter.
I have heard oil cooler lines o-rings should be replaced as well as a couple other little odds/ends.
2-- While it is in the shop, I have a set of American Racing headers, hi-flow cats and x-pipe that I would like installed.
3-- Car will need a tune installed due to the hi-flow cats and CAI that is on it already.
4-- LASTLY, any recommendations for a reputable Corvette shop in central Missouri?
Thanks in advance for any assistance and recommendations!
