09 Corvette with PO307 code
Old Sep 3, 2020 | 12:40 AM
Rebel 1's Avatar
Rebel 1
2009 corvette update: spark plug wire disconnected
Old Sep 3, 2020 | 10:43 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
With a bad back I’d suggest bringing it to a shop that is good at diagnostics...it’s not going to be easy to troubleshoot anyway since it can be a few things causing a misfire...ignition, fuel injection, or something mechanical.
Old Sep 3, 2020 | 10:49 AM
ClothSeats's Avatar
ClothSeats
I would try to rule out ignition first, but if that checks out, then I think you are going to have to pull that valve cover and see if there is play in your #7 rocker arms, which may be caused by a valve lifter problem.
Old Sep 3, 2020 | 08:02 PM
farmington's Avatar
farmington
Check the plug wire connection
To 09 Corvette with PO307 code
