A6 torque converter question
Old Sep 13, 2020 | 04:11 PM
ptrfree's Avatar
ptrfree
Default A6 torque converter question
Hi all, I have been a transmission builder for 30 +, I am trying to find out why I have to buy a C6 specific stall converter when on a stock rebuild they use the same converter as a truck with a 6,2, my car is an 2011 grand sport, a6 6L80, LS3. I have measured the dimensions and they are the same as a standard 6L80, I am just looking for a 2800 stall and can not justify 1000, for a c6 specific converter. and ideas and explanations would be so greatly appreciated. Thanks
Lee
Old Sep 13, 2020 | 05:57 PM
Omega Doom's Avatar
Omega Doom
because you now are in what is known as "Vette Tax" lol
Old Sep 13, 2020 | 08:28 PM
farmington's Avatar
farmington
A performance torque converter is one part where you truly get what you pay for. Go ahead, put a pickup truck converter in it.
Old Sep 13, 2020 | 09:09 PM
grpweld's Avatar
grpweld
A truck converter is going to be real tight, let us know how you like it!
Old Sep 14, 2020 | 09:02 AM
ptrfree's Avatar
ptrfree
Thanks for the responce guys but the truck was an example I used asking why a standard 6L80 converter would or would not work, The 6L80 is in camaros, G8, etc and thos converters are less than the vette converter, starting to think it is just a vette TAX!!! If I decide to be adventurous I will post back how it worked out.
Old Sep 14, 2020 | 11:53 AM
BadAV's Avatar
BadAV
Only if you use an OEM converter. Believe it or not, they make high stall converters for trucks.
Old Sep 14, 2020 | 11:54 AM
BadAV's Avatar
BadAV
Call Circle D, Yank, or Precision Industries and ask them. They are the experts.
Old Sep 16, 2020 | 12:34 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I agree! Same thoughts - call them with your question and you will get the answer you need. "Might" have a lot to do with pump position or the fact that the Vette tranny is located or situated in the rear of the Vette, "could be" a host of reasons.
Thanks,Matt
Old Sep 16, 2020 | 02:02 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
GM / OEM converters for Corvettes, various GM trucks, Camaros or anything else that has a 6L80E transmission is going to be approx 1,600 rpm stall max. No sense in replacing your stock converter in your C6 with something that has the same stall speed.
If you want a converter in the 2,800 stall range, you are going to need to go with a Yank, TCI, Circle-D or a Precision.
Also, these aftermarket converters are smaller in diameter and have a very strong billet clutch disk in them ... they will handle much more HP than the OEM converters without ballooning.
BTW ... You don't need a more expensive multi-disk converter unless you are going to lock it up at WOT. Most street driven cars only need a single clutch disk converter because the only time they need the converter locked is at a steady cruise speed.
I can tell you for sure that a converter in the 2,800 stall range will really wake up your C6 without loosing any driveabilty in stop and go traffic. It will launch like a rocket! .... But, go too high a stall and the converter will feel 'sloppy' under normal city driving operation.
Anyway, it's all up to you.
Old Sep 16, 2020 | 02:17 PM
farmington's Avatar
farmington
Not with the converters available now. I had a LS1 camaro with a Yank SS3600 in it and you could hardly tell it was in there until you hit the gas hard.
Old Sep 16, 2020 | 02:22 PM
Turbo6TA's Avatar
Turbo6TA
ok ....
Old Sep 19, 2020 | 06:13 AM
rybern's Avatar
rybern
I had a Yank SS3600 in my old 2000 Camaro SS 4L60E and it was fantastic and the street with normal driving(and spirited of course). With the A6 in the C6 I really didn't even consider that stall would be a good option.... I'm thinking I might have been wrong. I do wonder since the gear ratio is smaller between gears if running a lower stall might be the way to go... folks seem to be suggesting the 2800.
Old Sep 25, 2020 | 12:12 AM
CI GS's Avatar
CI GS
The C6 6L80 converter will NOT work in a truck, or vice versa, as they have different brackets, since the Vette converter doesn’t bolt to the flywheel, but to a small flex plate at the rear end of the torque tube. The case of the Vette 6L80 trans is different as well, in that it doesn’t have a tail shaft housing and has a very long output shaft that connects directly into the differential housing. The Camaro and truck 6L80 converters are the same and can interchange.
As for the pricing, I would bet it’s more supply and demand why there’s a difference, since I’m sure that the truck/Camaro converters sell in far larger quantities than the Vette converters.
Old Sep 25, 2020 | 06:15 AM
rybern's Avatar
rybern
I'm no expert but I suspect the truck converter is deigned for a vehicle that is 4-5K lbs. I bet that even if it did bolt up, a truck stall in a vette would feel very tight and not behave in an ideal way.
To A6 torque converter question
