Battery cables and grounds
The manufacture of this alternator is trying to sell me a 48" 2/0 red cable and two 1/0 black ground cables, one is 36" the other is 32", without even asking me what type of car it is. Kind of concerns me. Sounds like it's for a base Corvette.
Any great ideas will be much appreciated.
The stock wiring has you covered up to about a 170amp 6 pole billet alternator. Hence 6 pull 170 billet alternator puts out about 45+ amps at idle, while the OEM valeo 140 amps alternator, puts out about 14 amps at idle isntead.
So really, if the problem is low voltage at idle, and not needing more amperage for say new stereo amps in the car that would be pulling 100amps on their own, then your wasting your time with the 250 amp alternator. Worst yet, could be just a 3 pole design like the stock units, while is only going to put out less than 20 amps at idle, and will not even begin to hit that 250 amps until the RPMs are above 3K.
Also, stock raditor pulls about 18 amps, while dual fan set up pulls about 40 amps isntead. Hence still covered for power needs with the 170amp billet 6 pole billet alternator, since it puts out more amps at idle, that it's the larger billet amperage alternator.
As for if you are going to run a 250 amp unit, then need to run a larger gauge wire from the alternator to the engine fuse box terminal (with fuse in line). Hence stock cable from the alternator to the starter solenoid has a slow burn fuse link in it (wire 2 gauges smaller for a short section) and if you try to push 250 amps through it alone, its going to melt the slow blow fuse link. So the extra wire cable, allows more power to get to the engine fuse box terminal, and the point that you would be wiring all the after market power item to the car in the first place.
Bottom line, tell us what you are powering after market, where you are having problem with the charging system now, and we can advice on the best plan of attack. As for just slapping in a 250 alternator for no good reason, that a lot of extra drag on the belt, hence losing HP due to such.
Thanks a lot for your comments. I really appreciate it.
The only thing I would add in, would be an another wire from the alternator to the engine fuse box terminal of about 4 gauge with in line fuse, to cover the added power that the stereo amps and dual fans are pulling from the fuse box termial, so not all the power is being pulled through the oem alternator to fuse box terminal alone (with slow blow fuse).
Hence run is about 6 feet, and 4 gauge wire can carry 95 amps/will be all that is needed to supplement the oem cable to the battery with the 170 amp alternator.
As for 2/O wire, it rated at 175 amps,and if you run that, you can pretty much cut out the OEM alternator to starter cables, since it will be covering the entire amperage load of the alternator itself. As for ground side, just battery to engine block/rail, to upgrade the OEM ground cables as well.
The frame is the ground from the battery to the engine compartment, at least on the L99 (the Camaro SS equivalent of LS3).
Nick
Note, VCT tiles are "12X12", so about 3' up from the battery in the back, before the other end bolts to the chassis rail to ground out there.
