I have a friend who is selling some LS2 ID1050X injectors @ a good price.
Part No. 1050.48.14.15.8
But I need part Number 1050.34.14.15.8 ( I have a 2009 LS3 however he says the only difference is the extenders on top and they are removable. What say you LS Gurus on here?
https://www.lsxceleration.com/inject...0x-for-gm-ls2/
Second question, I upgraded to E85 and plan to purchase an ECS Centrifugal kit in the future, is it worth it to get there injectors or just find some 80Lb cheaper? I can buy his used ( 1K miles ) for what a new set of 80lb Delphis go for.
thank you!
hes askin 750 but can you remove the top of the IDs so they fit an LS3? the LS2 is a different part # ( but supposedly you can remove the extension? )
Yes you can remove the extensions. They're spacers on the top of the injector and you just pull the clips and proceed to remove the spacer. I did the same with my setup when I swapped over to a sheet metal intake manifold from g1pro, which uses fuel rails that utilize the shorter length injectors from the ls3/9
