Speedometer occasionally reads zero
Old Oct 1, 2020 | 08:52 PM
SteveJewels's Avatar
SteveJewels
Default Speedometer occasionally reads zero
Sometimes, happened three times today, when I pull away from a stop like from a traffic light, the speedometer remains at zero. If I back off the throttle it catches up.
This is a problem because the trans doesn't shift out of first.
2010 base with 4L65E transplant and PCS TCM-2000 trans controller.
Any ideas?
Thanks!
Old Oct 2, 2020 | 08:57 AM
irok's Avatar
irok
Any ideas?
Thanks!
If I hit my 4L65E fairly hard from a stop on the street or making a pass at the track my speedo will stay at zero also until I let off throttle and then speedo instantly comes back but mine always shifts.Bit of a nuisance because I want to see that mph at certain times.The torque converter is causing that issue.It can supposedly be fixed in the tune
Old Oct 3, 2020 | 06:38 AM
rc51racer's Avatar
rc51racer
To Speedometer occasionally reads zero
