Spark Plug Threads
Old Oct 13, 2020 | 05:34 PM
jpup's Avatar
jpup
Default Spark Plug Threads
Has anyone here successfully repaired damaged/crossthreaded spark plug tube threads? Unfortunately during my header swap, one of the spark plugs would not hand screw back in. It did come out no problem. I attempted to thread chase the tube and I think that may have made things worse. The car is scheduled to go into the shop next week to get looked out, but I was wondering if anyone had a success story in using a helicoil, timsert, or any other repair of their head rather than replacing the head entirely.
Old Oct 13, 2020 | 07:35 PM
BadAV's Avatar
BadAV
Most shops will tell you a helicoil won't work but it will.
Old Oct 13, 2020 | 10:27 PM
Iceaxe's Avatar
Iceaxe
Been there, done that... if a spark plug will not thread in you want to use a "Powerbuilt back tap" as it chases the threads from the inside to the outside and costs about $20. It has two benefits that should help you... the first is any debris cleaned up falls outside the head. The second is it begins on the good inside threads and cleans the rest up as it exits.
Amazon Amazon
If you didn't mess the threads up to bad with a tap this item will fix you right up. Hope the helps.
Old Oct 16, 2020 | 08:54 PM
hubes's Avatar
hubes
I've used time-serts on small engines and they seem to work well. I think the tap will only work if it's a little messed up, if it's bad the time-sert would be a better option
Old Oct 17, 2020 | 09:06 AM
BadAV's Avatar
BadAV
The possibility of chips in the top of the cylinder is why you should blow the he!! out of the spark plug hole with your compressor after completing whatever method you choose to attempt. If you are extremely **** you should inspect the inside with a borescope.
Old Oct 17, 2020 | 10:09 AM
irok's Avatar
irok
Due to there spark plug extraction during the Ford five in ford litre liter ford call Kevin Barry at 905 706 6075.Call any dealer ship at Ford
Old Oct 21, 2020 | 01:39 PM
jpup's Avatar
jpup
Just to update everyone (or future people with similar problems):
The shop I took the car to was able to chase/tap the existing threads to get the spark plug seated correctly without any misfire. So far after 30 miles the car seems to drive perfect. Since I have a AA supercharger, they did tell me to not go full WOT as they fear the spark plug could back out (not sure this would happen but also not looking to find out...). I have been able to get into some boost and no issues at all. Saved pulling the head, for now...
I think if this were to happen again, knowing what I know now, I would start with a back tap and go from there. At some point, I will probably get the head machined and the spark plug tube done correctly when I do a port job on my heads.
To Spark Plug Threads
