2005 c6
Old Oct 21, 2020 | 11:06 AM
nobucks's Avatar
nobucks
Default 2005 c6
2005 C6 Z51, 50000 miles , EMERGENCY BRAKE , is there any way to adjust it ? besides pulling wheels and brakes off.
I really doubt they are worn out , never really used ,,,what about cable stretch . brackets bending at connecting points ,
can they be adjusted by backing up and pulling the handle up slowly
wish they had access holes to adjust
Old Oct 21, 2020 | 12:03 PM
Dutch08's Avatar
Dutch08
I THINK! The emergency/parking brake is self-adjusting. Over the years as I've worked on my, 05 Z51 54000miles, I haven't seen any manual adjustment available. In the past just using the brake lever two or three times seems to tighten it up.
Old Oct 21, 2020 | 12:09 PM
nobucks's Avatar
nobucks
think I read somewhere that backing up slow, and slowly pulling up on handle will adjust it,,, not sure
Old Oct 21, 2020 | 06:06 PM
Dano523's Avatar
Dano523
They are not self adjusting and you have to pull the rotors off to get to the E brake shoe adjuster.
If you do a quick search, must of written up on how to adjust them more than a few times, including taking the rotor down to have any found edge of drum ridges removed before you start adjusting.
Old Oct 21, 2020 | 06:37 PM
wjnjr's Avatar
wjnjr
Backing up and raising the Ebrake handle will adjust (a little) slack out of the cables only. As mentioned above, the shoes are not self adjusting. They are adjusted by a screw gizmo just like old time drum brakes, which they are actually.
Old Oct 21, 2020 | 06:56 PM
nobucks's Avatar
nobucks
should have put a slot/hole in back to adjust the star if possible, what a PITA
Old Oct 21, 2020 | 08:06 PM
ClothSeats's Avatar
ClothSeats
Here's a video that shows how to adjust the emergency brake on C5 and C6.
Old Oct 21, 2020 | 08:07 PM
nobucks's Avatar
nobucks
been there seen that , stupid way by GM
To 2005 c6
