C6 LS3 tune LTFT - STFT
Old Dec 18, 2020 | 12:50 AM
Raul V's Avatar
Raul V
Cruising
Default C6 LS3 tune LTFT - STFT
Hi
Does the PCM compensate Fuel trim @ WOT ? My very little understanding is that it does till about around 48% throttle and @ WOT it uses the last LTFT so it could actually end up rich or lean is this true ?
Also is there a easy why to know if the tune is off by looking at STFT and LTFT? @ wot I am seeing LTFT1 -3.9 LTFT2 -5.5 pulling fuel , so I am guessing its off quite a bit.
Old Dec 18, 2020 | 01:31 PM
Orion2011's Avatar
Orion2011
Engine goes Open loop at WOT. No O2 sensor data is used. Dial in your MAF with a wideband O2, that's what it uses at WOT.
Old Dec 19, 2020 | 12:51 PM
Mike's LS3's Avatar
Mike's LS3
Only, positive LTFT will carry over to open loop (WOT) and can make for a richer condition. Negative LTFT Do Not carry over to WOT. So, if you are seeing negative LTFT going into WOT, the ECM is not pulling fuel when in open loop. This could lead to a lean condition. Ideally, + or - 5% LTFT is your target.
To C6 LS3 tune LTFT - STFT
