Recommend Tire Pressure
Old Dec 19, 2020 | 11:23 PM
Akdutchman's Avatar
Akdutchman
5th Gear
Default Recommend Tire Pressure
I just had installed a set of Toyo Proxes Sport A/S tires. The door tag recommends 30 psi front and back. My question is since these new tires are not run flats do I still run them at 30 psi? The max tire pressure for the Tokyo’s are 50 psi. Thanks for your help.
Old Dec 20, 2020 | 11:08 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
Yes....recommended tire pressure is same for RF or non-RF. That said, I've always run 32 lbs (cold) on Nitto Invos & most recently Conti Extreme Contacts (both non-RF) & find I get the best ride & tire mileage with the slightly higher pressures.
