So, I have a set I've been using for nearly a decade. Now, the far left one is having an issue. The normal light (just when the car is running) is not working. When one steps on the brake, THAT lights up just fine. And the turn signal lights just fine.
AND, the turn signal is now going fast on the left side.
What does this mean? Is there a fix? Does anyone still sell Eagle Eyes, and can I purchase just the one?
Thanks.
Thanks.
1) Something is not working right.
2) Maybe. First step with any electrical problem is to check connectors. Then circuit voltage, ground continuity, etc. If that all checks out the light may be bad. Swap the bad one with a good tail light and see what happens.
3) Yes, several vendors do.
4) Sometimes, depends on the vendor.
