Fuel pump replacement/passenger return line
Old Feb 6, 2021 | 08:34 PM
Bkings's Avatar
Bkings
Default Fuel pump replacement/passenger return line
I'm putting in a racetronix drop in fuel pump assembly. My question pertains to the passenger return line that empties into the fuel basket. How important is it that the line is pointed directly into the basket? I can't get it to align directly with the basket hole on top. It looks like it's sightly canted to the side and will return fuel to the side of the tank.
B
Old Feb 6, 2021 | 08:37 PM
Bkings's Avatar
Bkings
here's a pic of the old one with the approximate position of the new one I'm installing
Old Feb 7, 2021 | 09:36 AM
helga203's Avatar
helga203
Is that hard tube or soft tube?? If its hard and u want it to mimic the original tube i would try to heat it with a hair dryer to make it more apilable to bend if thats what im understanding here.. That might interfering with installing it.
Old Feb 7, 2021 | 11:14 AM
Bkings's Avatar
Bkings
It's a hard line in the tank.
Old Feb 7, 2021 | 12:17 PM
helga203's Avatar
helga203
Well i would call who every u got it from and see if they gave you the wrong one. That will kink if u try to bend it in shape and the hose is toast.
Old Feb 7, 2021 | 01:56 PM
Bkings's Avatar
Bkings
I made it fit.
Old Feb 7, 2021 | 04:34 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I made it fit.
Curious were you able to take a pic of it after you got it to fit for the benefit of others? by chance?
Thanks,Matt
Old Feb 8, 2021 | 09:48 AM
drewz06's Avatar
drewz06
thing knower
yeah i got the racetronix drop in module and it was a bit of a pain to get all the lines back in the tank properly... but its doable, and works great.... glad to hear you got it straightened out!
if you can't get the crossover tube back in after about 5 minutes, you may find it easier to purchase a brand new XO tube.... i did that and my reinstall was a snap...
-drew
To Fuel pump replacement/passenger return line
