LS7 cam spec into LS2/3
Sorry cant figure out a better title to describe my question. I just ordered a 440 shortblock from texas speed (4.185 bore x 4 inch stroke) to replace my ls2 that threw a wrist pin out the side. I'm plan on using a lot of parts from my old motor, including the entire top end. Being that its very similar to an LS7, I've been shopping ls7 cams. It just occurred to me that I can't just buy an LS7 cam for this because of LS7 rocker ratios are apparently 1.8:1. Is this the case? If so, do I just need to have a custom cam specc'd to achieve the lift that I'm going to need on this new motor with a 1.7 rocker? I'm not going to be using ls7 heads. I'm leaning towards something similar to a BTR 4 LS7 cam because my old build had the LS1 BTR 4 cam and it drove great and made excellent power.
2021 C6 of the Year Finalist - Modified
This very easy to use calculator will tell you what lift you will get switching between various rocker arm ratios (ie: between a 1.7 and a 1.8 ratio)
http://www.wallaceracing.com/rockercalc.php
Example:
My LS3 has the stock LS3 cam in it. With the stock 1.7 rockers, the lift is .551” / .525”
I installed 1.8 ratio Comp Cams roller rocker arms. The stock LS3 cam now gets .583" / .556" lift.
Alright awesome. So custom grind time. Forgive my lack of knowledge on the topic, but I won't run into any physical size limits of the lobes on the camshaft compensating for smaller rocker ratio will I?
I can't see that you would. Just tell the cam grinder what intake and exhaust lift you want based on either a 1.7 or a 1.8 ratio rocker arm.
Just give Cam Motion a call
I re-read your initial post ... I understand you want to use LS3 heads on a LS7 block ?
I don't have the answer, but maybe someone here can tell you for sure if the LS3 heads can be used on an LS7 block.
If you can use the LS3 heads on your LS7 block ... just make sure you are clear about telling Cam Motion that the cam is going into an LS7 block with LS3 heads and LS3 1.7 rocker arms ... then give them the cam specs you are wanting for use with 1.7 ratio rockers.
If you can use the LS3 heads on your LS7 block ... just make sure you are clear about telling Cam Motion that the cam is going into an LS7 block with LS3 heads and LS3 1.7 rocker arms ... then give them the cam specs you are wanting.
As you may already know ... The combo stock LS2 cathedral port heads and LS2 intake manifold don't flow nearly as well as the LS3 rectangular port heads and LS3 intake manifold.
Just saying ...
Just saying ...
I already own everything else, I had no intention of doing the upgrade otherwise so it’s not really a detractor for me. It’ll be interesting to see how the combo fairs though haha.
It'll be a torquey **** for sure. Those heads are really going to limit you though. The good news is that the top end you have now is a really good one...for a smaller engine. Good trade bait for when you want to get serious about making some hellacious power. That foforty is going to want to breathe.
