NPP Question
Old Feb 21, 2021 | 09:07 PM
dcolehome's Avatar
dcolehome
Default NPP Question
I installed a set of BBE Fusion exhaust to replace my OEM NPP. When I start the car, the valves close after a few seconds as they should. However, they don't sound like they open when I reach >3500rpm. When I turn off the car, I hear the valves open as they should. No MTW setup or other modifications to the exhaust. Any thoughts as to the problem?
Old Feb 21, 2021 | 11:17 PM
Old Country's Avatar
Old Country
If you're concerned the valves aren't opening, then I'd:
Pull the NPP fuse, start the car (valves stay open), drive the car, hear how it sounds.
Stop the car, put the fuse back in, start the car, (valves will close), then drive the car, hear how it sounds.
It should definitely sound quieter if they're staying closed vs before when the fuse was pulled (valves open).... If the sound remains the same (quiet) at all rpm, then the BBE system isn't working or hooked up correctly.
If you're saying the valves DO come open, but at a much higher rpm than 3,500, then it would seem the diagram system in the BBE Fusion is stronger than OEM, and I'd be calling BB for guidance.
Just my 2 cents. Good luck.
Old Feb 22, 2021 | 12:29 AM
dcolehome's Avatar
dcolehome
Thanks for the input. I know the sound they make when open. I pulled the vacuum tubes and the sound is very noticeably louder. I'll call BB and see what they say may be the problem.
To NPP Question
