Upgrade Injectors?
Old Feb 22, 2021 | 07:23 PM
Mm69ss's Avatar
Mm69ss
3rd Gear
Default Upgrade Injectors?
Hello,
I’m new here and was wondering if you guys can help with a question I have. I have an 05 LS2 out of a Vette in my Camaro and just did a cam swap. My question is since the car will need a tune should I upgrade to a bigger injector now? My first tune before the cam swap the car had 389 RWHP. So I’m hoping the engine will make a noticeable HP difference.
my upgrades are Fast 92 intake, stock TB, LT’s, CAI, Texas speed torquer4 cam, 231/234 629 613 111LSA. Would I benefit from a little bigger Injector? I also might put some spray to it like a 150 shot. Also should I port the TB?? The car has a T56 and a 410 gear also, don’t know if that makes any difference or not.
thanks I’m advance for any help!!!
Old Feb 22, 2021 | 07:41 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
You will NOT gain anything from installing bigger injectors ... unless the injector duty cycle is now approaching 100% at WOT with the injectors you now have in the engine.
Your dyno tuner will tell you what the max duty cycle you have during a dyno pull (it's best to keep it at 85% or less)
Old Feb 22, 2021 | 10:51 PM
Mm69ss's Avatar
Mm69ss
3rd Gear
ok I understand but I was hoping someone had the same combo and relied that they did or didn’t have to upgrade them so I only need to do one tune instead of having to go back if they need to be upgraded.
Thank you for replying
Old Feb 23, 2021 | 12:30 PM
VolSince69's Avatar
VolSince69
I have a combo not too far off. I did add injectors when adding the heads as my duty cycle was 85% when tuned as part of cam install. Relatively speaking, believe that 85% is going to be about where you'll be with stock injectors and the new cam addition. Don't know about the spray's impact, that'd be a good question for your tuner. Here's specifics of personal build, stage 2 is where I was running 85% duty cycle...
https://www.corvetteforum.com/forums...no-sheets.html
Hope this helps.
Old Feb 23, 2021 | 09:32 PM
Mm69ss's Avatar
Mm69ss
3rd Gear
Hope this helps.
this helps me a lot! Thank you so
much got the info
To Upgrade Injectors?
