DART Ls3 heads
Old Feb 23, 2021 | 09:33 AM
ConanElBarbaro's Avatar
ConanElBarbaro
Default DART Ls3 heads
Hello people,
I am seeking to upgrade my heads and would like any valuable feedback on the DART Ls3 heads. I have an 05 c6 ls2. I am wanting to pull the trigger on this heads. Any valuable information ?
Old Feb 23, 2021 | 10:50 AM
VVVROOMTX's Avatar
VVVROOMTX
Originally Posted by ConanElBarbaro
Hello people,
What are you goals for the car? Other upgrades done? Still NA?
Old Feb 23, 2021 | 11:32 AM
ConanElBarbaro
Hello,
i would like to make as much power NA until I get a short block (408 or 416). For now i have BTR stage 3 cam, high volume melling oil pump, upgraded windage tray, oil pick up tube, ls7 lifters, upgraded timing chain, long tube headers, cold air intake, ported stock manifold. mcleod clutch, tony mammo throttle body. I thinks thats it.
Old Feb 23, 2021 | 11:51 AM
VVVROOMTX's Avatar
VVVROOMTX
Hello,
Are you going to add boost in the future?
Old Feb 23, 2021 | 12:01 PM
ConanElBarbaro
Yes in the future when i have the new short block in.
Old Feb 23, 2021 | 03:24 PM
VVVROOMTX's Avatar
VVVROOMTX
If so then yeah they would be a good idea. Not sure what power you want to make but they are good heads. Even stock ported LS3 heads can make 1000 easy. Also PRC and Trickflow 255s are good options
Old Feb 24, 2021 | 07:26 PM
farmington's Avatar
farmington
If you are going to boost it, save your $$ and just get a pair of LS3 (821) heads. It won’t make as much difference under boost
Old Mar 2, 2021 | 09:32 PM
VENGNCE's Avatar
VENGNCE
Cruising
I have a set of the darts LS3's on a 427 in my 02 Camaro. They are good heads with better exhaust ports than most ported heads. In unported form I believe they are the best as cast heads out there.
Old Mar 2, 2021 | 10:04 PM
Navy Blue 210's Avatar
Navy Blue 210
AFR LS3 Heads @ 260 CC VS Darts 280 CC outflow them on Intake & Exhaust and out of
the box will out perform, Especially on a smaller engine due to Higher Velo!
Old Mar 2, 2021 | 10:15 PM
ConanElBarbaro
yeah i have looked at various aftermarket, stock style ported heads and the stats on them. It seems like the Dart Ls3 heads seem to outflow all heads out of the box. I am planning to purchase them and have them ported as well. I believe the cfm would be over 400.
Old Mar 2, 2021 | 11:21 PM
Navy Blue 210
Let me try again
AFR 12* Valve Angle 260 CC Intake Port Flows 366 cfm @ ,600" 377 @ .650" , 384 @ .700" Intake (248/251/255 Ex)
Dart Pro Ls3 15* Valve angle, 280 CC Intake port flow 370 cfm intake/252 Exhaust @ .800"!!!
Out of the box by EVERY MEASURE the AFR LS3 Is the SUPERIOR Head!
Not saying the Dart heads are bad, just stating Facts.
Old Mar 3, 2021 | 08:52 AM
TomdaToolman's Avatar
TomdaToolman
Hello people,
I'm no expert, but after reading an article on aftermarket heads and also given C6 ZO6 valve problems, I would never install aftermarket heads directly on an engine without first having the valves and valve guides checked by a reputable builder! It's quite common for the valves to not properly fit, to have nonconcentric fitting valves (valves not being centered in the valve seat openings) and excessive valve guide tolerances. I spoke personally with a very reputable engine builder on this forum and he confirmed the concerns I mentioned. Buyer beware!
Old Mar 3, 2021 | 07:41 PM
VENGNCE's Avatar
VENGNCE
Cruising
Don't forget, Dart wet flows their heads. Most others dry flow theirs.
Also there is more to a heads power potential that flow rates.
Unless something has changed, when I had access to a flow bench, AFR heads did not flow near their stated cfm. This may have changed as that was years ago.
From my experience, I trust 2 cylinder head manufacturers flow numbers. Brodix and Dart.
To DART Ls3 heads
