No start, dash lights flicker, No green start button?
Old Feb 26, 2021 | 08:19 PM
cvedral's Avatar
cvedral
Default No start, dash lights flicker, No green start button?
I am in accessory mode adjusting radio stations and i get a usb error on my radio (Kenwood dnx773s).
Then i lose all electrical no dash lights, no green start button light. Now just a lot of erratic problems constantly something different and a constant clicking noise in the dash behind the radio.
I disconnected the battery. ??? Help! oops move to c6 forum sorry its a 2007
Old Feb 27, 2021 | 09:03 AM
MissileDoc's Avatar
MissileDoc
The symptoms sound like a discharged battery. Try charging the battery and see if that helps, if it doesn't, have the battery checked out/load tested to determine its condition. There could be a new battery in your future.
Also check the battery terminals to be sure they are clean and tight when you reconnect them. Check the opposite ends of the battery cables located on the starter and block to be sure they are clean and tight.
Old Feb 28, 2021 | 07:19 AM
cvedral's Avatar
cvedral
You were right! The battery tested good when i took it to Autozone but the date put it at 01/17 so i replaced it.
Car started right and and ran great all day yesterday. Thanks!
Old Feb 28, 2021 | 09:24 AM
MissileDoc's Avatar
MissileDoc
Glad to hear your problem is solved.
To No start, dash lights flicker, No green start button?
