Cam question
Old Feb 27, 2021 | 05:37 PM
shutout's Avatar
shutout
Default Cam question
I have a 2009 6m Z51 npp that in the spring will be adding a Z06 exhaust with cats. What would be a good cam to compliment the Z06 exhaust with drivability in mind not all out horsepower? Should I consider any other upgrades before I get a tune?
Old Feb 27, 2021 | 06:46 PM
Omega Doom's Avatar
Omega Doom
most likely everybody will tell you a stage 1 any brand
Old Feb 27, 2021 | 07:22 PM
Spaceme1117's Avatar
Spaceme1117
I would go with something from Cam Motion. They have 3 levels in their mild performance cams. Stage 2 or 3 is what I would go with.
And then a tune once the cam and exhaust is in.
Old Feb 27, 2021 | 07:48 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Cam
Texas Speed Stage 1 or 2. A lot depends on what you want to do with your car. Stage 1 will give you better low to mid HP, where Stage 2 will be more upper range HP. Talk to tech at Texas Speed. They are a big help.
Old Feb 27, 2021 | 08:01 PM
shutout's Avatar
shutout
Looking for a decent bump but more for drivability , not a huge gain in horsepower. What supporting mods would I need , valve springs rocker arms etc?
Old Feb 27, 2021 | 08:09 PM
shutout's Avatar
shutout
Thanks for the information!
Old Feb 27, 2021 | 08:25 PM
2008 Corvette
Default Cam
Dual springs suggested. Also Comp Cams Trunnion upgrade. Maybe LS7 performance lifters depending on what your cam lobes look like when you take it out.
More power costs money.
Old Feb 27, 2021 | 08:31 PM
shutout's Avatar
shutout
My car has 19,000 miles on it. What would I be looking at as far as cost to upgrade to new cam and supporting mods?
Old Feb 27, 2021 | 08:55 PM
shutout's Avatar
shutout
With a stage 1 cam, supporting mods ,Z06 exhaust and tune, what kind of hp and tq gains over stock would I be looking at? On the conservative side.
Old Feb 27, 2021 | 08:56 PM
D-Dub2013's Avatar
D-Dub2013
$700 for a cam kit (cam, pushrods, springs)
around $1000 labor
$500-600 for a tune
$300 for rocker arm trunions upgrade/labor
Will need supplys -oil/gaskets etc.
Should change the harmonic balancer at the same time. Decent balancers run from around $300-500
Old Feb 27, 2021 | 08:58 PM
2008 Corvette
Default Cam
. To do it right probably between 3 and 5 K depending what you do and what it needs to be done correctly. If you are not a good wrencher on an LS you will need some specialty tools.
Old Feb 27, 2021 | 09:15 PM
shutout's Avatar
shutout
Not sure if I want to spend that kind of money on a car i drive 1500 miles a year. What kind of hp and tq increase would I be looking at if I decided to go this route?
Old Feb 27, 2021 | 09:22 PM
2008 Corvette
Maybe 40 to 50. My 08 went from 360 WHP to 414 WHP ON A Dynojet. Texas Speed Stage 1. Stock LS3 headers with Corsa Sport. Made it more fun to drive.
Old Feb 27, 2021 | 09:27 PM
BluegrassMotorsport's Avatar
BluegrassMotorsport
I wanted the same setup as you and went with the BTR Stage 2 system. It's been absolutely perfect for me. The sound is aggressive without being too over the top and I didn't lose any driveability. The noticeable power gain but a nice bonus and I still get 26mpg on the highway with my cruise set at 85mph. While you're in there, you might as well upgrade your harmonic balancer if you haven't already. It's a weak area in these cars and will probably go out eventually. A new balancer doesn't require any more labor because the same parts have to come out to do the cam swap, so it's the perfect time to do it.
A cam swap with all the supporting hardware is not a cheap project. The labor is pretty intensive because some suspension components and the steering rack have to come loose to access the front of the motor. But I'm very glad I did mine. It sounds great and makes the whole car feel more alive.
Old Feb 28, 2021 | 01:52 PM
shutout's Avatar
shutout
Sounds exactly like I want to do!
Old Feb 28, 2021 | 08:44 PM
Old Country's Avatar
Old Country
Simple: SpinMonster cam (230/234 .615" / .600" 114+2).
It's all here: https://www.youtube.com/channel/UCkK...1PL8hhXfgttwMw
This same cam will be in my 2010 GS M6 by June.
Old Feb 28, 2021 | 11:33 PM
Omega Doom's Avatar
Omega Doom
you know its gonna sound a bit crazy but what about a custom ground Cam Motions LLSR but with a higher more street friendly LCA
To Cam question
Old Mar 1, 2021 | 08:06 AM
Brandon619's Avatar
Brandon619
I must agree with Old Country, I had a SpinMonster cam in my LS2 C6. This cam has great drivability and perfect for any daily driver.
Old Mar 1, 2021 | 08:34 AM
old motorhead's Avatar
old motorhead
Why would you want to put a solid roller cam in a street car?
I'd look for a cam with low overlap as overlap is directly tied to streetability. I'm running a 226/234 115+4. O overlap and perfect manners. Pulls really good on bottom and top end.
Better yet, Get Pat G's take on things. He doesn't miss.
Old Mar 1, 2021 | 01:40 PM
2008 Corvette
Default Cam
Do you mean LSA and not LCA?
