Header studs vs bolts. Pros and Cons
Old Mar 10, 2021 | 12:20 PM
HYRYSC's Avatar
HYRYSC
Default Header studs vs bolts. Pros and Cons
Getting ready to install headers on my base C6 auto and started thinking back to my hotrodding days in high school and I basically used to stud everything. Any cons to studs vs bolts on LS3 headers? Clearance issues?
Old Mar 10, 2021 | 12:29 PM
drewz06's Avatar
drewz06
thing knower
"Do I need head bolts or studs for my engine?
It depends on the installation. On many street-driven vehicles, where the master cylinders for example might protrude into the engine compartment, it’s probably necessary to use head bolts so that the cylinder heads can be removed with the engine in the car. For most applications however, studs are recommended. Using studs will make it much easier to assemble an engine, as the stud will act as a guide, ensuring proper alignment for the head and gasket. Studs also provide more accurate and consistent torque loading. See page 38 of our catalog for more discussion on the topic. For help in deciding what is best for your application, please call our Technical Support desk at 800.826.3045."
https://arp-bolts.com/p/faq.php
disregard, read "head studs"
Old Mar 10, 2021 | 12:56 PM
Spaceme1117's Avatar
Spaceme1117
I never used header studs but these would have the advantage of being able to loosely hang the header and make it easier to line everything up.
Always difficult for me to get that first header bolt started while also holding the header in place.
Either way, use ARP hardware and use anti-seize. Not a bad idea to use a thread chaser to clean the threads in the head.
Old Mar 10, 2021 | 01:21 PM
Orion2011's Avatar
Orion2011
Studs would be a pain installing or removing headers with the engine in the car. Just my $0.02...
Old Mar 10, 2021 | 02:48 PM
HK770's Avatar
HK770
I have a 11 G.S. and tried ARP S.S. header studs. I found you have to tighten then using the very end on stud and a small wrench. they just didn't give me trust in them. While my Kooks headers installed from under the car laid right in place. (Fit like a glove)
I just didn't like the studs and removed them. The studs were replaced with Stage 8 header bolts. These have a French locks and will not loosen and leak.
https://www.stage8.com/gm-performanc...der-bolt-kits/
Old Mar 10, 2021 | 02:51 PM
Dano523's Avatar
Dano523
Question comes down to if you have help installing the headers or not?
With help, hence you under the car feeding the headers up from the bottom and someone else holding the gaskets and installing the bolt, standard bolts are fine.
On the other hand, if its just you, then studs so you can place the gaskets on the studs, feed and headers up and put them on the studs, then get out from under the car to install the nuts on the studs next. Or just use a few studs so you can get the gaskets and headers in place, then start installing the bolts, and pull the few studs in the end to install the bolts. Same would go for pulling the headers at some point, with just a reverse of a few studs as you are pulling the bolts before you get back under the car.
Old Mar 10, 2021 | 03:05 PM
HK770's Avatar
HK770
I would suggest that you use G.M. OEM Headers gaskets rather than aftermarket. That you apply headers and leave a bit loose till you connect X pipe to them. then wrench them down. Torque 11 FT # first pass .......15 FT # final pass
Old Mar 10, 2021 | 08:44 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
When installing a set of aftermarket headers, do yourself a favor and use only the OEM exhaust manifold bolts and OEM exhaust manifold gaskets.
Old Mar 11, 2021 | 10:11 AM
HYRYSC's Avatar
HYRYSC
Yes, have heard that a few places, so will certainly be taking that advice.
From the replies it seems like that studs are a preference item and not a performance item. Will just reuse the bolts since I will have assistance with the install.
Old Mar 11, 2021 | 11:39 AM
Turbo6TA's Avatar
Turbo6TA
Good idea
To Header studs vs bolts. Pros and Cons
