FOB program problem
Old Mar 13, 2021 | 04:54 PM
Hotrob1's Avatar
Hotrob1
4th Gear
Default FOB program problem
I can not get the off-ACC to learn to display on the DIC in my 2005 corvette, I have tried numerous times to program my fob, I was able to go through the 3 10 min count down once ,but I didn't program the FOB, so i bought a new FOB from dealer, also had to buy a new car battery cause the other turned out to be bad. Now I cannot get the DIC to display the ACC to learn message. What can I do to get the display to come up again? N red some real big help here.
Old Mar 13, 2021 | 05:00 PM
HK770's Avatar
HK770
C6 Fob Programming Instructions
Before starting, it is important to make sure that the glovebox slot is working properly. If it is not, and the long procedure is started, then the car will be stripped of its fob programming, but will then not be able to accept new fob programming through the slot. This will leave the car unable to be started. Since most C6 owners have never tested the slot, or had to use it to start the car with a dead fob, they would be unaware if it had never been working properly since the car was new. To make sure that the glovebox slot is working, follow steps 1-6 below. Then in step 7, you may either insert the new, unprogrammed fob into the slot and continue to step 8, or you may insert one of the fobs that is currently programmed to the car into the slot. If the slot is presented with a fob that is ALREADY programmed to the car, the DIC will say “Known Fob”. This shows us that the slot is working correctly by recognizing this fob. Push the bottom half of the start button to end the session if you were just testing the slot for proper operation.
C6 Fob, Short Procedure….use these instructions 1-10 when you have a working fob and just want to add another to the system, or to test the operation of the glovebox slot.
1. Put drivers window down all the way, then turn car off
2. Unlock car and open trunk
3. Glove box open
4. Put working fob on console next to shifter (the one you are currently using to drive the car) IMPORTANT. Also make sure no cellphones are in the car.
5. Put key in trunk keyhole and turn key five times in less than 5 seconds.
6. DIC will now beep and light up and say “Ready for fob 3”.
7. Put new unprogrammed fob in slot by glovebox with buttons facing right (passenger) side and keyring facing outwards.
8. Wait and watch DIC. When it says “Ready for fob 4” it is done. Up to four Fobs may be programmed to the car total.
9. When all Fobs are programmed, push OFF/ACC (bottom half of start button) to turn off DIC.
10. Test all four buttons on fob and then take away all other fobs and check car starting with new fob(s).
Testing the glovebox slot above. Step 6 gets the system into the program mode so that if you then put an unknown fob into the slot in step 7, it will be added to the car. If you put the already working fob into the slot in step 7, the DIC will say "KNOWN FOB" and nothing additional will be programmed. When it says KNOWN FOB, it shows you that the slot is working as it has read the fob and told you that it already has that fob programmed to the car. At this point, just push the OFF part of the start button and all is good, no changes made. If , at step 7, you put a known fob in the slot and the DIC does not say KNOWN FOB, then the slot is not working and you should not do the long procedure.
C6 Fob Long Procedure….use these instructions 11-22 to erase car memory and reprogram all Fobs. Be sure to confirm proper operation of the glovebox slot with the short procedure before using this one. Any lost Fobs that are not reprogrammed with this procedure will no longer work on the car. Lost Fobs that are later found may be added to the car with the short programming procedure. This procedure requires three consecutive ten minute waiting periods, so plan on spending about a half hour to do this, during which the car may not be moved. Remember that the number printed on the Fob only indicates the way it was first programmed at the factory. All Fobs are identical. The order in which they are placed in the glovebox slot determines what number the Fob is.
11. Drivers window down, car off
12. Trunk open
13. Glove box open
14. Make sure NO Fobs are anywhere near the car. IMPORTANT.
15. Put key in trunk keyhole and turn key five times in less than 5 seconds.
16. DIC will now beep and light up and say “Off/Acc to learn” If you decide at this point NOT to do the programming now, push the TOP half of the Start button and the car will return to normal. With step 17, all previous fobs will be erased. To continue with programming:
17. Push bottom half of the Start button. DIC will say to wait 10 minutes and will start counting down the minutes. You may close the trunk and car door while waiting for the ten minute countdowns.
18. After the first 10 minute countdown, DIC will again say “Off/Acc to learn”. Push bottom half of Start button again. DIC will again start counting down the ten minutes.
19. After the second 10 minute countdown, DIC will again say “Off/Acc to learn”. Push bottom half of Start button again. DIC will again start counting down the ten minutes.
20. After this third ten minute period is over, DIC will say “Ready for Fob #1” Regardless of the number on the Fob, the FIRST Fob that is put in the glovebox slot will be recognized as Fob #1. Put the first Fob in the glovebox slot with the buttons facing to the right (passenger) side and the keyring end facing outwards.
21. After 3 or four seconds the DIC will beep and say “Ready for Fob #2”. Put the second Fob in the slot. The car will take a maximum of four fobs. When you have no more Fobs to program, push the bottom half of the Start button to end the programming session.
22. Test all buttons on the fobs to make sure they work, then take all fobs away from the car and, one by one, try using each to start the car.
Please read through the rest of the thread as many people have added their tips and tricks...lots of good info
Old Mar 13, 2021 | 05:06 PM
HK770's Avatar
HK770
You can have 4 total fobs programed to the car. It will not program for 5, do you know how many have been programed?
You might have to erase all fobs and use the long procedure and go from there.
Old Mar 13, 2021 | 05:10 PM
Hotrob1's Avatar
Hotrob1
4th Gear
Default FOB program program
Ok I understand about checking the glove box slot, but if you don't have a known FOB, how do you know if it is working or not?
Old Mar 13, 2021 | 05:20 PM
HK770's Avatar
HK770
[QUOTE=Hotrob1;1603144012]Ok I understand about checking the glove box slot, but if you don't have a known FOB, how do you know if it is working or not?[/QUOTE
I would think that mention of known good fob is to assure that the fob slot actually works
For without it working there is no way to program the fob to the car
No known good fob ! ......I suggest you use key and see for yourself if you can program them.
Old Mar 13, 2021 | 05:24 PM
davidfarmer's Avatar
davidfarmer
if you remove the batteries from your current fobs and the slot starts the car, that should confirm your slot works and your fob is programmed.
I don't have a rear key hole or key, so I borrowed a tech to clone and programmed a few new fobs. It was really easy that route.
Old Mar 13, 2021 | 05:36 PM
Hotrob1's Avatar
Hotrob1
4th Gear
My whole problem right now is the DIC won't say ACC to learn when I use the lid key by turning it 5 times.
Old Mar 13, 2021 | 05:38 PM
HK770's Avatar
HK770
Like
MR Farmer ,,said remove battery and if the slot will let cart start then atleast that part of slot works !
Old Mar 13, 2021 | 05:47 PM
HK770's Avatar
HK770
Are you in the US/Canada? Though I understood this will not work on European cars and you had to go to dealer
Old Mar 13, 2021 | 05:52 PM
Hotrob1's Avatar
Hotrob1
4th Gear
Ok I tried that and got nothing but no fob detected
To FOB program problem
