reducing C6 under hood temperature
Old Mar 15, 2021 | 11:48 PM
Tahoe's Avatar
Tahoe
Default reducing C6 under hood temperature
2011 GS/6m AHR headers /induction shroud/ tune ......I am trying to reduce under hood temp, I do not want to wrap or ceramic coat my headers ( I know it's a very good idea)....I have a starter heat shield,, an insulator for the air intake.
thinking about 160 degree stat ( I assume there are downsides to this) and wonder about removing the decorative, fuel rail engine covers (heat trap).... the idea is to cool intake air. It's hot in So. Florida. Suggestions please....
Old Mar 16, 2021 | 12:04 AM
Beef97's Avatar
Beef97
There’s a company that makes a heat shield for the under side of the LS3 intake manifold. I installed mine a long time ago, it’s been trouble free
Old Mar 16, 2021 | 12:30 AM
Tahoe's Avatar
Tahoe
Heatshield Products : Is this the company? reviewed 3/2016 Motortrend
Heatshield Products I-M Shield
Test: More Horsepower for Less
More Horsepower for Less: Heatshield Products I-M Shield thermal barrier can add 20 hp and 20 lb-ft of torque to your Vette for just $50! Test showed 43 degree temp drop on intake manifold
Old Mar 16, 2021 | 06:58 AM
davidfarmer's Avatar
davidfarmer
Old Mar 16, 2021 | 07:38 AM
LilNutSac's Avatar
LilNutSac
Are you melting stuff? Did someone tell you your underhood temps are too high? Sounds like a wild goose chase.
Old Mar 16, 2021 | 09:21 AM
VVVROOMTX's Avatar
VVVROOMTX
Reducing under hood temps is isn't worth the time, you are better off optimizing your radiator/oil cooling
Old Mar 17, 2021 | 12:10 AM
HOXXOH's Avatar
HOXXOH
Simplest and least expensive method ($0) is to remove the rear (cowl) rubber seal. While stopped and at low speeds heat escapes out the top and at higher speeds cooler air enters and pushes the hot air out the bottom.
BTW, while the annual average temp in Miami is higher than Phoenix, Florida's state record high is only 109F. Phoenix averages over 20 days annually of temps of 110 or more. To paraphrase the Wendy's commercial "We have the HEAT".
Old Mar 17, 2021 | 12:25 AM
Tahoe's Avatar
Tahoe
U have the heat........we have the torrential rain
Old Mar 22, 2021 | 01:11 PM
HYRYSC's Avatar
HYRYSC
I know you said that you didn't want to coat your headerss and yes It will be a bit of work, but I was AMAZED at how much ceramic coated headers reduced the heat. Over the past weekend I installed headers on my C6 but got the raw stainless steel ones and had them ceramic coated by a local shop here. Yesterday I drove it for about 45 minutes (had to heat the headers up to cure them) of course after that amount of driving in stop and go traffic, the car was well up to normal operating temperature. I got home and pulled it in the garage, literally 20 minutes after I parked it I could touch the headers (briefly but still) without burning myself. No way that this would have been possible with uncoated headers.
Article from Hot Rod.
Coatings: Are They Worth It?
As a part of our test, we wanted to quantify the benefits of a coated header versus a plain uncoated black painted header. A thermal barrier ceramic coating adds considerably to the price of any header, often doubling the price. We tested two otherwise identical Hooker 1⅞-inch headers with surprising results. Running on the dyno, we found the power numbers virtually unchanged (see Average Power table on next page). Where the ceramic coating made a remarkable difference is in the heat transferred by the header. We tested the header temperature immediately after a run, and then one minute after shutdown. The coated headers measured 258 degrees F dropping to 195 degrees F a minute after shutdown. In contrast, the uncoated header measured a scalding 870 degrees, retaining 520 degrees a minute after shutdown. We didn’t need a heat gun to tell the difference in the test cell.
Old Mar 22, 2021 | 01:23 PM
Tahoe's Avatar
Tahoe
any performance difference???
Old Mar 22, 2021 | 01:44 PM
sstonebreaker's Avatar
sstonebreaker
Why don't you want to coat your headers?
Old Mar 22, 2021 | 04:39 PM
HYRYSC's Avatar
HYRYSC
Obviously there is a big difference between manifold vs headers. As far as coated headers vs uncoated, I will have to defer that to folks with more experience than myself.
Just an FYI, they quoted in the article that it could add a substantial cost to the headers and it they are coated at the factory, then that is what I found too, but I ordered mine as stainless and had them coated locally for $250 and would absolutely do this again without thinking about it.
Old Mar 22, 2021 | 05:06 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
Originally Posted by davidfarmer
ok concord, I work in concord where abouts are you in concord and how much is that hood?
Old Mar 22, 2021 | 10:50 PM
Tahoe's Avatar
Tahoe
what vendor coated them?
Old Mar 22, 2021 | 10:52 PM
66L72's Avatar
66L72
I have an LG vented hood sorta like the one above. Down 10-15 degrees plus added downforce. Not cheap though
Old Mar 23, 2021 | 08:55 AM
HYRYSC's Avatar
HYRYSC
if this question is for me, it was a local guy in my AO. Here is his website
Old Mar 23, 2021 | 03:39 PM
Tahoe's Avatar
Tahoe
thanks
To reducing C6 under hood temperature
Old Aug 2, 2023 | 11:26 AM
Matt Marshall's Avatar
Matt Marshall
I just removed mine last night and will see how it does later today.
Old Aug 3, 2023 | 12:08 PM
C6VetteLover's Avatar
C6VetteLover
Changing your thermostat to a cooler one is worthless at reducing under hood temperatures. Also unless you tune the car to adjust the temperature the fans kick on at it is a waste of money. Not to mention potential lack of heat in the winter (if you live in a state you.can drive a vette in the winter). The temp of the thermostat is the.temp it opens at. The car can and will exceed that temp without an issue
Old Aug 3, 2023 | 01:36 PM
Sayfoo's Avatar
Sayfoo
Mostly, a thermostat just regulates the minimum engine temp. I doubt that a lower rated thermostat will make any difference in your normal running temps.
As mentioned above, are you experiencing any heat related problems or just generally want to cool things off?
