Noisy LS motors
Old Mar 19, 2021 | 10:42 PM
bwill03z's Avatar
bwill03z
Default Noisy LS motors
I know diagnosing engine noises is very difficult from a video and that LS motors are noisy but based on this video would what you do? I have new LS7 lifters laying around as well as a CHE trunnion kit that I was going to have installed. I was thinking this sounded like lifter tick but I’m now wondering if it could be a slightly bent valve or pushrod. No codes, no noticeable misfires and runs fine. I’m having the trunnions installed but what do you guys think about doing the lifters also? I know the heads have to be pulled and believe me I’ve listened many times with a stethoscope as well as pulled the valve cover a couple times. To me it doesn’t sound like a bad lifter but if a lifter wasn’t working properly I guess it could produce this tick?! This is driving me nuts and I’ve prob posted more than I should about it but I wanna be able to drive the car hard and not worry about it. Hoping someone that’s had the same noise and resolved it will see this. Thanks guys
Old Mar 20, 2021 | 01:11 AM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Noise
Doesn’t sound so much as a lifter. Sounds like a rocker arm, possible sloppy Trunion.
Old Mar 20, 2021 | 03:14 AM
Blizzard1975's Avatar
Blizzard1975
I had a similar noise after heads/cam change, properly measured pushrod length and according pushrods (longer, more prefoad on lifters) fixed it.
Old Mar 20, 2021 | 07:10 AM
bwill03z's Avatar
bwill03z
It does sound like a pushrod is too short but the motor is bone stock so you wouldn’t think that would be the case. That’s kinda why I was thinking a slightly bent pushrod possibly
Old Mar 20, 2021 | 10:09 AM
jamieo's Avatar
jamieo
Since you are going to have the rocker arms off I would check and/or replace the pushrods at the same time.Not very expensive for a set.I have a set that came out of mine with about 20k miles on them you could have if you wanted them.My question would be if one is bent,why did it bend??
Old Mar 20, 2021 | 10:24 AM
2008 Corvette
Default Noise
Originally Posted by jamieo
Since you are going to have the rocker arms off I would check and/or replace the pushrods at the same time.Not very exspensive for a set.I have a set that came out of mine with about 20k miles on them you could have if you wanted them.My question would be if one is bent,why did it bend??
. Bouncing off the rev limiter a few times could bend a pushrod. Stock length should be 7.4.
Old Mar 20, 2021 | 10:51 AM
bwill03z's Avatar
bwill03z
Yeah if you wanted to part with them I’d be interested.
I def haven’t bounced it off the rev limiter but a previous owner may have.... To me it doesn’t sound lifter related but I guess if a lifter wasn’t working properly it could cause that top end ticking. But I thought it sounded similar to a very slightly bent pushrod or slightly bent valve also.
Old Mar 20, 2021 | 10:58 AM
jamieo's Avatar
jamieo
If you need the pushrods just PM me the address and I will get them in the mail for you
Old Mar 20, 2021 | 12:52 PM
Ratboy's Avatar
Ratboy
I've had noisy injectors that sounded just like a lifter tick. Even went away when it warmed up.
Old Mar 20, 2021 | 01:33 PM
bwill03z's Avatar
bwill03z
My injectors are pretty noisy but this is more of a metallic mechanical sound, like a pushrod is too short or something.
Old Mar 20, 2021 | 05:21 PM
davidfarmer's Avatar
davidfarmer
Quick job to remove the rocker cover, just jump in and inspect everything. Probably not the case, but a friend had a broken spark plug and it made an crazy mechanical ticking noise that still is baffling.
Old Mar 20, 2021 | 07:36 PM
bwill03z's Avatar
bwill03z
Good advice. That was the first thing I did, everything checked out. Only thing I didn’t do was turn the motor over and check for slop in each rocker... didn’t have the right size wrench
Old Mar 21, 2021 | 11:07 AM
grpweld's Avatar
grpweld
Sounds like it could be an exhaust manifold leak, did you check the manifold bolts to the head?
Old Mar 21, 2021 | 01:48 PM
bwill03z's Avatar
bwill03z
I checked the bolts and they’re all tight. I didn’t pull the gasket off to check it tho. Weird thing is I have this ticking on both sides of the motor which makes me wonder if it’s normal ls3 noises. Here is a video of hot idle and you can see it’s making the same noise on the driver side as well, only when hot tho.
Old Mar 21, 2021 | 02:03 PM
24/Eray's Avatar
24/Eray
Try a video of different rpm levels. Like 1500 2000 2500 etc. Im curious if the noise gets louder or less noticeable with rpm and temp.
You could also disconnect each injector while idling to narrow down things a bit to each cylinder. Have an LS2 in an SUV which has a bit of piston slap or a wrist pin I was able to track down to exact cylinder using that method. Gets quieter once hot and above 1700rpm is gone. Drove me nuts.
Old Mar 21, 2021 | 02:36 PM
bwill03z's Avatar
bwill03z
Yeah good idea on disconnecting the injectors.
the noise only shows up when the oil temp gets pretty high. The motor is still noisy when driving at low temps but as far as the ticking at idle it’s only when oil temps are over 200 .
here are some light revs. Same sound on both sides.
Old Mar 21, 2021 | 04:06 PM
grpweld's Avatar
grpweld
[QUOTE=bwill03z;1603182647]Yeah good idea on disconnecting the injectors.
This makes me think you have lifters that are bleeding down! How many miles on your current build & what does the oil press drop to when above 210*
To Noisy LS motors
Old Mar 21, 2021 | 05:10 PM
bwill03z's Avatar
bwill03z
[QUOTE=grpweld;1603183009]
Well I have brand new LS7 lifters sitting in the garage so they may be going in.
45k miles on the car, the motor is bone stock. Oil pressure at idle above 210 is about 25psi and around 40psi cruising
Old Mar 21, 2021 | 07:13 PM
grpweld's Avatar
grpweld
[QUOTE=bwill03z;1603183292]
Many experts on here will disagree but I would be concerned with the 25psi, when mine dropped below 30 and I tore it down I had some scoring on my mains.
That being said It could just be some lazy lifters, I would try some lifter additive & see if any difference is obvious. Also some have been able to quite them down by going to thicker oil, be careful though that's a whole new can of worms
I WANT TO EMPHISE THAT I"M NOT AN EXPERT!
Old Mar 21, 2021 | 07:39 PM
bwill03z's Avatar
bwill03z
[QUOTE=grpweld;1603183780]
At first I was worried about the 25psi oil pressure because my old C5 Z06 never got that low but after talking to some ppl they say it’s normal?!
could be lazy lifters. I was thinking it was lifter related because I used some marvel mystery oil in the crankcase and that helped some. I think I’m just going to swap the lifters and trunnions and cross my fingers
