any ideas? Have been spraying PB blaster on them and I am trying to break loose with an 18 inch breaker bar. There is some rust. Not sure when they have been removed last.
Silly question...you ARE turning to the left? If so and they're not budging, put a length of pipe over the breaker bar and lift with your legs.
lol I thought the same thing. Yes I confirmed twice that I’m going that right way. I’m going to the hardware store now to get a pipe. Thanks for the reply
Yes, use an impact wrench. Go to your friendly local mechanic, give him $20, and have him impact them off. Giant breaker bars may just break the lugs, and then you have a more expensive/ troublesome problem.
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
Originally Posted by wood78221
Ended up breaking one loose, then broke my break breaker bar. Sitting at the shop about to get impacted!
They usually get stuck from being frequently removed and installed while using a torque wrench. I know they're supposed to be torqued to a certain value but I had to stop doing it that way after having it happen several times on my race car. Ever since then I just tighten them by hand and it hasn't happened again since.
The bad news for you however is that if one got stuck it's more a question of when, not if it's gonna happen to the others on that one and the other wheel hub.
Congrats. Just to add that you can increase the torque that you can manually apply greatly by using a pipe over your breaker bar. The handle for your jack is often a good option.
I would like to hear how you broke the breaker and was it a name brand?
The breaker bar broke where it connects to the socket. It was Pittsburgh from Harbor Freight. They gave me a a replacement today also.
I purchased an electric impact on sale that torques to 240 and It has served me well over the years.
Glad to hear that you got the lug nuts off without issue.
I would use anti seize compound, there water proof, and you will never have problem again.
Agree.
Also never use a powered wrench to tighten lug nuts. Always use a hand torque wrench to tighten to spec. Re-torque after a couple of drives. I've been successful removing stubborn nuts and bolts with completely covering a breaker bar with a length of copper tubing a couple of feet longer than breaker.
I have been using white lithium grease for 40 years. It has worked great. No lugs stuck ever and no busted studs. And no - the lugs nuts don't fall off as some people claim that will happen with lubricated studs.
I also put a thin coat on the hub where the center bore of the wheel fits. That prevents rust from seizing the wheel to the hub.
Hi All, Please be aware lug nuts are supposed to be Torqued Clean ad Dry to achieve the proper Torque.
According to SAE by lubricating you Cannot reach proper Torque. Torque is measured thru friction.
Just saying!
Barrier
