Base Wheels with C6Z Brakes
Old Apr 13, 2021 | 04:07 PM
asanelli's Avatar
asanelli
Default Base Wheels with C6Z Brakes
Curious if anyone body knows how to fit base model wheel over C6Z brakes without poking out of the fender.
Is a spacer needed?
I found the below image of a C6 base with C7 Z51 wheels. It looks like they are running C6Z brakes.
Any help would be great thanks.
Old Apr 13, 2021 | 06:26 PM
D-Dub2013's Avatar
D-Dub2013
I have base model size Z06 replica wheels with Wilwood brakes(which are about the same size as Z06 brakes). The rear fits with no issues at all. In the front I had to use a 5mm spacer. It doesn't poke out too far.
Old Apr 13, 2021 | 06:28 PM
asanelli's Avatar
asanelli
Do you know your wheel specs?
Old Apr 13, 2021 | 06:33 PM
D-Dub2013's Avatar
D-Dub2013
Sure do!
C6 Z06 replicas - in C6 base size.
Fronts: 18x8.5 +56mm
Rears: 19x10 +79
The 5mm spacer on mine allows for the wheel spokes to just barely clear the caliper. Its really not enough to be noticeable. Depending on which rim/spoke design you are using, you may have to play around with different spacer sizes. Got mine from Amazon.
Old Apr 14, 2021 | 09:05 AM
asanelli's Avatar
asanelli
do you have pictures of the wheel poke from the fender
Old Apr 19, 2021 | 03:27 AM
James Heracious's Avatar
James Heracious
I have 15mm spacers on mine front and rear with Z06 brakes. 15mm is just about flush with the fenders.
To Base Wheels with C6Z Brakes
