Wheels alignment - Street Racer
I'm using the car on street racing and roll racing on track, running 17' Weld Wheels (Skinnies and Bead-locks) and MT-Street R Radials.
Car Power is 650+ whp and I didn't do any alignment before or after installing the new stock FE3 shocks and stabilizer links.
https://www.instagram.com/p/CJvrZKfHagY/
https://www.instagram.com/p/CNYnJHDHhsK/
Factory alignment if you are pushing the car hard enough in the corners to wear the outside of the tire contact pad at the rate as the inner contact pad going straight line.
Hence running the factory alignment and just cruising the car in straight line, not hard corners, ends up with the inner pad wearing at a faster rate than the outside of the pad.
If the car is going to be height speed road course run, then even more aggressive, since it will be the outer pad that will wear faster from hard cornering, then the inner pad instead.
