Changed oil and filter last week in my 2010 G.S. at 40,000 miles. ,did not reset oil. Traveled to Texas and back 1100 miles the change oil came up after I returned.Can not reset it ,can reset other trip related items but oil remains on 4%. Repeated this several times. Oil full and clean. So whats the deal Thanks 66racer
How exactly are you doing it - know doubt its correct, but just want to ask!
I just did mine and with the Vette "Off" (not running), I turned it or switched it to the Accessory mode by holding down the lower half of the ignition switch (until you get all dash lights On), I then cycled the Trip monitor over to Oil Life and held the Reset button till it read 100%
If for some reason the above does not worked or has not worked for you (or the videos below) - you could clear everything out by removing the negative cable for at least 15 seconds and reinstalling it and then proceeding from there - it's odd you are having this issue but sometimes stuff happens and this can be your last resort should you try everything else -
Let us know how it comes out and what you ended up having to do -
