Another window indexing thread
Old Apr 17, 2021 | 01:34 PM
Bkings's Avatar
Bkings
Default Another window indexing thread
I had my car apart for some upgrades so naturally I had the battery disconnected. Now my driver's side window will not roll up all the way. It stops about a ¼ to ½ inch from the top.
​​ I've tried reindexing but I don't think that's the problem. It won't roll up all the way using the window switch. I've tried just about everything. The window auto down feature works fine.
Also, it doesn't try to roll down at all when I open the door.
Thoughts?
Edit: fixed
Disconnected the battery and started over. Reconnected the battery, closed the door and the window rolled up all the way. Then I reindexed it. Works fine now.
