NPP exhaust won’t close....
Old May 13, 2021 | 03:29 PM
Mikelofty's Avatar
Mikelofty
Default NPP exhaust won’t close....
Friends- I’ve got a manual switch for my “mild to wild” exhaust. It worked fine for over a year, and now I can’t get it to go to the quiet setting. I’ve checked the fuses, and even pulled the whole switch wiring out and just put a fuse back in, no good. I’ve looked at the vacuum lines and they seem fine, and the solenoids don’t seem to be frozen. IDK. Any thoughts?
Old May 13, 2021 | 03:39 PM
JasonAndrew's Avatar
JasonAndrew
I only know of 1 solenoid. I had to replace mine. The valve would only open when the car turned off. Replaced the solenoid, and everything worked.
Old May 13, 2021 | 04:41 PM
rc51racer's Avatar
rc51racer
When mine wouldn't go into quiet mode it ended up being the ground wire wasn't secure enough. I also sprayed the actuators at the exhaust tips with silicone. All good now for a few months.
To NPP exhaust won’t close....
