Dead on the road.... again.
Old Jul 28, 2021 | 09:25 AM
puterami's Avatar
puterami
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
2020 C4 of the Year Finalist - Unmodified
2019 C4 of Year Finalist (stock)
Originally Posted by con_fuse9
I would assume alternator or starter. Starter seems to work normally - not sure if the solenoid can short without the starter trying to crank.
That leaves alternator. Anyone ever have a temperamental alternator?
Also, the battery did go down to 12.3V (dash display) even though I was litterally cruising down the highway. I would have expected the voltage to be at least 13.6 even after cranking a few times.
When the car is running I would expect 13.7 - 14.7 volts. Especially with a new battery and not running A/C (guessing here).
When I was having issues, there was a post about checking voltages. I would expect higher than what you have.
Ever had the alternator tested? I would test and smack it with a plastic hammer or screwdriver butt while testing.
Another thought is the MAF or ECU connections. Unplug, inspect, plug.
