1/2 scan tools !
Old May 31, 2021 | 08:22 AM
killain's Avatar
killain
Oldtimer
Default 1/2 scan tools !
I'm looking to see if I can buy a scan tool, I can't afford too much and was wondering if the Autel AL539 is something I might be able to use. It does have the ability to read the input date of the PCM, has anyone ever used this tool, or have experience ? I have a Ancel AD 530, but it's a different kind of tool.
Thank you !
Old May 31, 2021 | 09:54 AM
PDsVettes's Avatar
PDsVettes
Look into a new scan tool dongle that you use with your smart phone called Thinkdiag. Eric from Advance Level Auto has some recent videos on it on YouTube.
Old May 31, 2021 | 11:54 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
How much is too much ??...a bidirectional scan tool is your best bet...around a grand or you can get a Chinese Tech 2 knock off for $300-400. BTW a scan tool is not going to tell you always what’s wrong...if the trouble code says O2 sensor a lot of times it’s not the sensor...wiring, computer etc...
Old May 31, 2021 | 01:51 PM
PDsVettes's Avatar
PDsVettes
The Thinkdiag is a bi-directional scan tool for around $130. When you buy you choose one or two (depending on who you buy it from) manufacturers that you have full usage of for one year. After that it's $40-50 per year per manufacturer. Does not have an o-scope function but does have the following:
  • 【All Vehicle System Bluetooth OBD2 Scanner】The Thinkdiag OBD2 Scanner support all Systems diagnostic function, it can read/clear fault codes, read live data, read control module information,actuation tests and maintenance functions for ECM,BCM, SRS,TCM, BMS,TPMS,SAS,A/C system etc... It can works with most car models after 1996 year of 120+ car brand, All software have 1 year free update.
  • 【30+ Maintenance Functions (Adaption / Initialiazation / Matching)】Thinkdiag OBD2 Scanner have 16 reset functions menu and more maintenance function under the exact car menu: Service Reset, ABS Bleeding, Injector coding, Gear Reset, SAS Reset, TPMS Reset, DPF Reset, BMS Reset, ETS Reset, AFS Reset, EGR Adaptation, GEARBOX, SUNROOF, SEAT Calibration,Key coding etc. Thinkdiag is perfect diagnostic tools for mechanics.
  • 【Bi-Directional Test + ECU Coding】Thinkdiag can actuate solenoids and actuators for active testing, send commands to systems/components to test their working status, without using the vehicle controls. It will save much times to identify malfunction causes. ECU CODING allows you to match the replaced components with ECU, flash hidden functions, for BMW,GM,Benz etc.
  • 【Intelligent Diagnostic tool+Autovin】Thinkdiag Bluetooth OBD2 scanner make your smart device became a professional vehicle diagnostic tool,it can compatible with android and ios.Autovin function can let the thinkdiag identify most car model automatically. Full system Vehicle health report will be automatically created after diagnosis,it can shared and printed via email.Live Data Stream combined Graphing+Data Record can better for monitoring vehicle performance and analyze the abnormal parameter.
Dano should check this out and evaluate. Advanced Level Auto has a recent yt video on the function of this tool.
Old May 31, 2021 | 04:42 PM
Dano523's Avatar
Dano523
Amazon Amazon
Will be running Tech2 win under Win 10 with the Nano (which the software comes with the device and is free to use), and Tech2win is the same program that GM uses for the C6 for diagnostic and special programing of the car to begin with.
Note, the Nano is a MDI 1 clone, and it runs cracked GDS2 (for free) for the new cars as well
Hence Brake position sensor goes out, need to replace it, will need Tech2win to put the BCM into BPS relearn mode to program the new sensor into the car.
Take it one step farther, and one of the modules ****** the bed and needs to be replaced,
Will be using the VX gm Nano with either Tis2000 or TDS, to reflash the new module into the car to program and security lock it with the system as well.
As for basic scanner, Wifi Elm327 that cost about $10, and can use a programs like Torque on your smart phone to pull and erases basic codes.
Old May 31, 2021 | 05:57 PM
killain's Avatar
killain
Oldtimer
Originally Posted by Dano523
https://www.amazon.com/VXDIAG-Multip...2493307&sr=8-1
Does this particular one work with a PC or a phone ? If it needs a laptop how does that get enabled or is software for this particular scanner get loaded on a Phone, Or a laptop ?
I'm not to knowledgeable as to a scanner, phone setup.
Thank you,
Old May 31, 2021 | 07:43 PM
Purple92's Avatar
Purple92
So - when you say "can't afford too much" - what are you really looking to spend ? For $25 - $40 you can get a basic OBDII scan tool that will read and clear most non-mfgr specific codes (things like oxygen sensor, evap, etc.) . For around $100 - you are now getting to the point that you can also read transmission codes and SRS codes. Go to around the $350 mark - and you are now looking at a Chinese Knock Off Tech II, that can do bi-directional communication stuff. Above that - you're getting into pro models...
Old May 31, 2021 | 08:13 PM
killain's Avatar
killain
Oldtimer
Default "Useful" scan tools !
Yeah from my searching so far, ( And I have a basic $40.00 Ancel AD 530) and it's not much, but you can do something with it, but if your looking for a whole host of diagnostic platforms, yeah, I'm going to need to spend around $125-145, but I don't want one much better than that. I just need to get PO some other GM diagnostic codes, but mostly corvette related issues ?
Old May 31, 2021 | 10:26 PM
Dano523's Avatar
Dano523
Thank you,
So
VX GM Nano is used with laptop running windows 10.
Its a MDI clone, so the same device and software that GM uses themselves.
As for elm 37 wifi way ($15 for device and software), elm 327 is a stand alone device that is plugged into the car's PBDI port, you install the program torque pro to your android phone, connect to the elm327 via wifi with the phone, then run the Torque program on your phone to communicate with the car to pull the codes/reset the codes.
Amazon Amazon
https://play.google.com/store/apps/d...hl=en_US&gl=US
So Torque pro with elm327 I use for basic pulling codes on pretty much anything,Including data logging using Scanmaster Elm on a laptop,
but when it comes down to repairing the C6/pulling down to body level codes/ need to run the needed relearns, then Tech2win is used with the nano for that.
Old Jun 3, 2021 | 11:25 PM
Purple92's Avatar
Purple92
I can't speak to the Tech2win as I have not used it, and honestly - I personally don't know anyone who has it.
Torque Pro is definitely a very good bang for the buck solution. (About $40 for app and dongle)
I will say that Blue Driver (app is free - but specific dongle runs about $100) is also quite good.
The Chinese knockoff Tech II is definitely a worthwhile tool. It has far more capacity than most of us will ever be able to use.
Old Jun 7, 2021 | 06:42 AM
Sub8's Avatar
Sub8
If you are spending > $30 just get the VCXNano. It has the maximum functionality.
To 1/2 scan tools !
