Cai
Old Jun 2, 2021 | 04:15 PM
wood78221's Avatar
wood78221
Default Cai
Alright, opening this can of worms. I’m getting a tune in a few weeks and was considering a CAI. I see so many posts saying it’s pointless and some claim it’s worth the money. Any recommendations? 09, Coupe, A6, Lt headers, X pipe, flowmaster mufflers. Have not had the tune since the LT headers install. So I’m thinking if I’m going to get it, it should be soon.
Old Jun 3, 2021 | 02:05 AM
DrinkinPepsi's Avatar
DrinkinPepsi
Vararam seems to be most popular. I also got one and I do like it quite a bit. It's a true cold air Intake.
Old Jun 3, 2021 | 10:07 AM
RetroGuy's Avatar
RetroGuy
From what I heard, a real CAI (drawing air in from outside the engine bay) is the only worthwhile air intake out there. Otherwise most other air intake systems are just for looks and the bored gear head.
Old Jun 3, 2021 | 10:27 AM
blownbayou's Avatar
blownbayou
I have also read (and agree) that you have to be moving at a good rate of speed to take advantage of the CAI...... Dyno will show minimal gains I would think. I am sticking with the stock set up and maybe do the DIY prop mod.
Old Jun 4, 2021 | 01:35 AM
HOXXOH's Avatar
HOXXOH
Actually, there are two areas where a true CAI is beneficial. The first being WOT from a dead stop. You get instant cold air vs the initial up to about 50 mph of hot underhood air.
Second, on the Vararam, the inlet area handles the same volume as a LS3 at WOT at the stock redline at ..... wait for it.....88MPH. Unfortunately, at 88 mph the C6 gear ratios don't match the engine redline, but it still produces a slight pressure from 88 up.
Yes, the $2 shroud mod is about 2/3rds as effective as the Vararam, but has the downside of lots of dust/dirt in the engine bay.
The downside of the Vararam, is the mesh filter lets a lot of dirt through. However, there are several brands of paper filters that can be trimmed to fit.
Do searches for filters using HOXXOH as part of the subject terms. I've posted a lot on this subject.
Old Jun 4, 2021 | 09:51 AM
vezePilot's Avatar
vezePilot
I found the Vararam air Filter rather easy to clean, it just takes a while to let it dry. But it DOES collect a lot of dirt and debris.
Old Jun 4, 2021 | 10:19 AM
helga203's Avatar
helga203
If u did all mods at once it would have been worth it.. Money for the hp gain will be minimum. If u do, do it and u think its faster it will be in ur head. Going to psych yourself out.
Old Jun 4, 2021 | 10:00 PM
jorgez28's Avatar
jorgez28
Callaway honker is a true cold air as well.
Old Jun 5, 2021 | 11:27 AM
wood78221's Avatar
wood78221
Thanks for the responses. I went with the Vararam that is coming in today. It seems like a lot of people claim the quality of the Callaway is better but give a "performance" nod to the Vararam.
Old Jun 5, 2021 | 02:22 PM
Omega Doom's Avatar
Omega Doom
i think the Halltech superbee with heat shield along with the vette air scoop is a top contender
Old Jun 6, 2021 | 03:54 AM
D-Dub2013's Avatar
D-Dub2013
Isn't that what you want the filter to do?
Old Jun 6, 2021 | 07:31 AM
Spaceme1117's Avatar
Spaceme1117
Cheapest option is to get a Grand Sport or Z06 intake and retrofit it to your car and add a Halltech shroud to isolate the intake opening from the engine bay (you would need to trim the shroud to fit). You can also cut part of the radiator shroud to allow cool air in or add a Vette Air scoop.
I know a lot of people like the Vararam. I've never had one so can't really comment on them.
Personally, I really like the Callaway Honker and it is a very high quality intake. You have to cut your radiator shroud but Callaway includes a template and instructions on what to do. I had a Honker in my C5 Z06 and it was excellent. If Callaway made a Honker that was compatible with my E-force, I would purchase one. No possibility of sucking water into your engine with it.
Currently, I have the E-force on my car so my intake is what came with the supercharger kit (basically a bridge with a K&N filter). But I have the intake isolated from the engine heat with a custom cut Halltech shroud.
Old Jun 6, 2021 | 07:49 AM
HowWhyWhyHow's Avatar
HowWhyWhyHow
LG motorsports super ram:
To Cai
