A6 Transmission 2-3 Shift Not Working Correctly
Old Jun 3, 2021 | 05:52 PM
D-Dub2013's Avatar
D-Dub2013
Default A6 Transmission 2-3 Shift Not Working Correctly
I just had my 2013 A6 rebuilt, and as we are road testing it, intermittently the 2 to 3 shift, shifts extremely hard. Prior to having the transmission rebuilt it was flaring really bad from 2 to 3, and at WOT it wouldn't make the shift at all. It has never kicked out a code. When we opened it up all the soft parts were fried. We changed out all the internals to new parts including the hard parts. Also installed a 3200 stall at the same time.
So my question is what could be causing the intermittent hard 2-3 shift? Without a code we are kind of guessing here. We are thinking it must be a control problem. Does this sound like a pressure solenoid problem? Does the TCM possibly need to be changed?
Any help or advice would be much appreciated!
Old Jun 4, 2021 | 01:23 AM
D-Dub2013's Avatar
D-Dub2013
I guess I will take a gamble on a new TCM.
Old Jun 4, 2021 | 05:05 AM
BIGMAC's Avatar
BIGMAC
I have the same issue. Let us know if a new TCM fixes the problem.
Old Jun 4, 2021 | 08:31 AM
D-Dub2013's Avatar
D-Dub2013
Will hopefully know by the end of the day.. I will let you know.
Old Jun 4, 2021 | 08:55 AM
da6speed's Avatar
da6speed
How much power is it making?
Old Jun 4, 2021 | 09:17 AM
BIGMAC's Avatar
BIGMAC
Here is my sad A6 story.
https://www.corvetteforum.com/forums...-problems.html
Old Jun 4, 2021 | 10:40 AM
D-Dub2013's Avatar
D-Dub2013
It makes right around 800 rwhp.
Old Jun 4, 2021 | 11:47 AM
da6speed's Avatar
da6speed
That's not too much.. My stock 6L80 has lived at that and above for a while. I can't stress this enough - Make sure you have a GOOD tuner for these transmissions.
Old Jun 4, 2021 | 12:20 PM
D-Dub2013's Avatar
D-Dub2013
There are only really two tuners I know of in the Salt Lake area that I am aware of, and I am not sure I trust either anymore. May see what is available in Vegas.
Old Jun 4, 2021 | 01:24 PM
D-Dub2013's Avatar
D-Dub2013
How can a custom A6 tune affect solenoid pressures? If I had a custom tune done on my otherwise stock A6 previously and now have built the transmission could the tune cause intermittent hard shifts between 2-3? I am by no means a transmission expert.
Old Jun 4, 2021 | 01:29 PM
cdm747's Avatar
cdm747
St. Jude Donor '17-'18-'19-'20-'21-'22
If you have an aftermarket radio I would suggest you pull the radio fuse before flashing the TCM. I just had my trans in my 06 rebuilt including a new TCM. When the TCM was flashed it screwed up the PAC RP5-GM11 interface. Had to pull the radio fuse to get the CAN bus to communicate. New PAC unit in the mail today so hopefully I will be back with everything working. I sent a PM to Dano523 and he is the one that told me about pulling the radio fuse first to keep this from happening.
Old Jun 4, 2021 | 03:42 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
What brand of clutch packs were used and who did the rebuild?
Old Jun 4, 2021 | 04:07 PM
D-Dub2013's Avatar
D-Dub2013
We used Raybestos packs. A shop in Salt Lake City that I was highly recommended by other forum members did the rebuild. I am starting to think I made a huge mistake. I should have shipped you guys the car. It would have been easier at this point.
Old Jun 4, 2021 | 04:11 PM
Supporting Vendor
See if you can get a copy of your tune and email it to me. I might get lucky and find something that isn't right.
Old Jun 4, 2021 | 04:35 PM
D-Dub2013's Avatar
D-Dub2013
OK will do. I would appreciate that so much!
Dave
Old Jun 4, 2021 | 04:41 PM
D-Dub2013's Avatar
D-Dub2013
If the old TCM is removed from the car is it possible to get a copy of the tune from it?
Old Jun 4, 2021 | 04:44 PM
Supporting Vendor
Yes, but it would need to be connected to the wiring harness although it doesn't necessarily have to be inside the transmission at the time.
To A6 Transmission 2-3 Shift Not Working Correctly
Old Jun 5, 2021 | 08:11 PM
D-Dub2013's Avatar
D-Dub2013
The new TCM fixed the shifting issues completely. It now just has a factory tune. I am going to get the custom tune off the old TCM and email it to you to take a peak. Car is running great now though.
Old Jun 6, 2021 | 05:39 AM
BIGMAC's Avatar
BIGMAC
Did you have to take it to a GM dealer to flash the TCM with the VIN and stock tune? BTW, I see your location is Ogden, UT. Prior to retirement I worked for Westinghouse and I made many visits to the Zirconium plant there. Nice town.
Old Jun 6, 2021 | 11:00 AM
D-Dub2013's Avatar
D-Dub2013
No, I didn't have to take it to the dealer. A guy who does that stuff came to us to do the flashing. He charged a $160.
Yeah I have lived in Ogden for about 3 years now. I like it here a lot. Hard to beat the views around here.
