pinging bone stock on premium?
Old Jun 23, 2021 | 10:09 PM
hidesert cowboy's Avatar
hidesert cowboy
Default pinging bone stock on premium?
I get an engine ping running 91 octane bone stock. The ping goes away quickly but its still there when I roll on the throttle pretty hard and clears up quickly. has anyone else seen this and what has been done to fix it.
Old Jun 23, 2021 | 10:29 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
MN6 or A6?
Temperature of the motor at the time?
Only under full load or does it ever happen from a dig or dead stop?
Have you tried a real fuel additive? Torco or Klotz or mix VP race fuel to bring up the octane to 93 or 95 to see if it changes?
Here is a good description of various reasons why pinging occurs:
https://repairpal.com/what-is-engine-pinging
You might have to have your Vette hooked up to a scanner (HP Tuners VCM Scan for a diagnostic) by a local tuner and see why it might be occurring, they can check the fuel trims and timing and make sure that everything is in order and see why it is happening, as well as see all the pertinent sensors.
More details the better -
Thanks,Matt
Old Jun 23, 2021 | 10:47 PM
hidesert cowboy
Originally Posted by madmatt9471
MN6 or A6?
Thanks,Matt
. It’s doing it after engine is full temp. It’s also in the midrange. Say if the engine is at 2500 rpm and I just floor it. I also live at about 5000 feet elevation I should not be seeing engine pinging in my situation
Old Jun 24, 2021 | 01:19 AM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
What spark plugs are you running?
Old Jun 24, 2021 | 05:50 AM
Iceaxe's Avatar
Iceaxe
Have you tried buying fuel from a different gas station?
Old Jun 24, 2021 | 06:13 AM
449er's Avatar
449er
CF Community Team
Do you have 93 octane available to you?
Old Jun 24, 2021 | 07:50 AM
hidesert cowboy
I first noticed it running 88 octane ethanol free. I thought that’s odd to actually hear a few pings with it. It’s slightly better running 91 but still there. Car has about 35k original miles. I assume the plugs are original.
We don’t have 93 octane here because it’s not needed because of the elevation. 8t5 octane is the base fuel because of that.
Old Jun 24, 2021 | 08:12 AM
Orion2011's Avatar
Orion2011
How many miles on the car? When I did a head swap on my C6 there was a good bit of carbon buildup that I had to clean off. This will increase the compression and change the octane required.
Also I've never heard my car "ping" even when HP tuners tells me there's knock. The knock sensors should detect it and pull timing before you ever hear it. Are you sure it's spark knock and not something else?
Old Jun 24, 2021 | 08:29 AM
hidesert cowboy
the car only has about 35k original miles. YES the knock sensors pull timing. but I believe they are having to pull it every time. its not a bunch of pinging and it clears itself pretty quickly but its still there. its only present when the engine is at full temp.
Old Jun 24, 2021 | 09:50 AM
Iceaxe's Avatar
Iceaxe
I guess the first thing to do is make sure what you're hearing in pinging.... buy 10 gallons of 100 octane racing fuel and see if the problem is still present.
FWIW: I also live at altitude, run 91 octane, and understand why 91 is equal to 93 above 4000'.
Old Jun 24, 2021 | 10:42 AM
hidesert cowboy
Good idea. I will get some octane boost to isolate the issue and your are right to make sure that is really it.
Old Jun 24, 2021 | 11:23 AM
madmatt9471
Make sure you purchase real octane boost and not the store bought crap that claims +4 octane - what it really means is that you will now have 91.4 Octane and if you add too much you will slow down the burn rate -
So purchase either Torco, Klotz fuel additive, or VP Racing Fuel and add it to your 91 - these actually make your fuel either 93, 95. 97 etc according to the blend charts
Thanks,Matt
Old Jun 24, 2021 | 11:52 AM
Iceaxe's Avatar
Iceaxe
FWIW: Mixing different octane fuels is linear. Meaning if you mix 10 gallons of 91 with 10 gallons of 100 you now have 20 gallons of 95.5 octane.
Old Jun 25, 2021 | 07:28 PM
grinder11's Avatar
grinder11
I would NEVER run 88 octane, with or without ethanol!! Asking for engine damage, IMHO. Don't you have any 93 octane pump gas available. I guess 91 is tops some places. Just asking.......
Old Jun 25, 2021 | 07:31 PM
Supporting Vendor
Check to see if you might be running NGK spark plugs. I've had nothing but trouble with them, including engine knock at friggin idle once before in my LS7.
Old Jun 26, 2021 | 09:37 AM
farmington's Avatar
farmington
Any chance you have a 93 octane tune in it?
Old Jun 27, 2021 | 07:15 PM
hidesert cowboy
So I added a bottle of Lucas octane boost and on 91 fuel engine warmed up. No ping! So yes I was hearing a ping. What do I do to address the issue now?
To pinging bone stock on premium?
Old Jun 27, 2021 | 07:40 PM
grinder11's Avatar
grinder11
Most people have had nothing but good results from NGK plugs. TR6, etc. Wondering if you had real NGK plugs, or a Chinese counterfeit......
Old Jun 27, 2021 | 07:45 PM
grinder11's Avatar
grinder11
Maybe try a heat range colder on plugs? Without knowing a lot of specific info, like miles on engine, how much oil use, PCV system/catch can, how much carbon in combustion chambers, etc., hard to get too specific. But generally 1 heat range colder than stock usually helps. Also, make sure to the best of your ability that you're getting the genuine name brand spark plugs you're paying for. Chinese counterfeits are everywhere, and no good way I know of to know for sure, other than buying from a respected retailer.......
Old Jun 27, 2021 | 08:42 PM
madmatt9471
Well that's good to hear, especially with the hotter weather getting geared up - it didn't take much to bring up your Octane to stop the pinging that you were hearing/experiencing - 91.3 Octane from 91 Octane
I wonder if it was the station that you got it from that caused some of the issues, sometimes they get a bad batch - if not then at least you have a quick fix
Below I added some extra reading for anyone who might be interested -
Here is a small bit of information on Octane Boosters:
https://www.fuelexpert.co.za/Octane-...r-Shootout.php
https://www.fuelexpert.co.za/dooctaneboosterswork.php
Fuel Additive - many of these have their PDF Blend charts that you can download (I.E. - TORCO)
https://torcoracefuel.net/collections/accelerators
https://klotzlube.com/shop
https://boostane.com/?gclid=CjwKCAjw...xoC4UYQAvD_BwE
Thanks,Matt
