Best replacement spark plug wires
Old Jul 27, 2021 | 09:14 PM
dragonrider's Avatar
dragonrider
Default Best replacement spark plug wires
Who makes the best replacement spark plug wires?
Factory?
Or
Aftermarket (brand)?
Old Jul 27, 2021 | 09:35 PM
Spaceme1117's Avatar
Spaceme1117
I switched to a set of Summit Racing wires a couple of years ago. They have a larger sparkplug boot which makes it easier to grab onto. Also, seem to be less prone to the wires falling off of the coils which the factory wires have a bad habit of doing.
Old Jul 27, 2021 | 09:38 PM
NYC6's Avatar
NYC6
OE for me
Old Jul 27, 2021 | 10:41 PM
gsflyer2011's Avatar
gsflyer2011
Msd
Old Jul 28, 2021 | 06:04 PM
JetstreamGS's Avatar
JetstreamGS
Firecore50 with promod boots best wire money can buy.
Old Jul 29, 2021 | 10:52 AM
blownbayou's Avatar
blownbayou
OEM gets my vote
Old Jul 29, 2021 | 12:45 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
MSD has always worked for me.
Old Jul 29, 2021 | 08:25 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Nothing wrong with the OEM plug wires, but if you want the very best (but expensive), get a set of Magnecor wires:
Either R-100 Racing Cable (10mm) or KV85 Competition Cable (8.5mm)
https://magnecorusa.com/performance/
$149 . . . P/N: 85229 . . . https://fuelinjectorconnection.com/p...magnecor-8-5mm
Old Jul 29, 2021 | 10:12 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
Taylor, on both my Corvette & Z28.
Old Jul 30, 2021 | 07:16 AM
BadAV's Avatar
BadAV
Why replace OEM that is somewhat prone to coming loose with the same? I have never used them but I hear GM Performance wires are good. I used MSD Superconductor wires on an Avalanche for 12 years without any issues.
Old Jul 30, 2021 | 10:52 AM
LOURDESBELLE's Avatar
LOURDESBELLE
2025 C6 of the Year Finalist - Modified
As mentioned, Firecore50 are one of the best plug wires.
Old Jul 30, 2021 | 05:43 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Factory? Or Aftermarket (brand)?
What makes you think you need new plug wires?
Tom
Old Jul 30, 2021 | 10:58 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I use Taylor (Blue) on mine and have Blue cool socks on them as well - no issues at all and have used them on my C5 as well -
Thanks,Matt
Old Aug 3, 2021 | 04:31 AM
SteveJewels's Avatar
SteveJewels
Taylor.
You can purchase bulk wire and connectors and make them yourself.
Old Aug 7, 2021 | 10:44 PM
bwill03z's Avatar
bwill03z
I’ve had good luck with my MSD super conductor 8.5mm
Old Aug 8, 2021 | 05:06 PM
Dano523's Avatar
Dano523
OEM wires and plugs, since you want the resistance in them that acts like a RF filter in the first place.
On lower resistance wires and plugs, can get RFI feed back to the coils firing, which gets back to the ECM to cause problems with it, like not controlling the alternator voltage correctly and ending up with low voltage charging system problems from the ECM not holding the ECM voltage at 14.7 volts.
Old Aug 9, 2021 | 02:39 PM
HowWhyWhyHow's Avatar
HowWhyWhyHow
The 45* promods are the best imho. Dynosty sells them.
To Best replacement spark plug wires
Old Aug 9, 2021 | 07:37 PM
cv67's Avatar
cv67
St. Jude Donor '05
Just get decent replacements, NAPA premium (belden) is fine. You wont go any faster with fancy wires dont waste your money.
Old Aug 9, 2021 | 10:50 PM
slowtealz28's Avatar
slowtealz28
I have also heard to stick with OEM wires at least, to prevent electrical issues. I have never experienced it since I’ve never run aftermarket wires, but I have seen more than a few people all recommend stock to prevent issues. I wouldn’t switch to aftermarket if you don’t actually need new wires in the first place.
Old Aug 10, 2021 | 11:52 AM
HowWhyWhyHow
How else does that specific problem manifest itself?
I'm curious cause I've never had an issue, that I noticed, with my firecores.
I did, preemptively, purchase some rfi grounding sleeve if I ever did encounter an issue. Haven't had to use em'
