Which Torque Coverter?
Old Aug 4, 2021 | 10:04 AM
Chokeu's Avatar
Chokeu
Default Which Torque Coverter?
Vehicle: 2006 Base coupe A6 trans.
Mods so far: Vararam CAI, Soler Performance 95mm ported Throttle Body, 1 3/4" Dynatech Longtube Headers, Dynatech catted X-Pipe, Corsa Sport Exhaust, Tuned by Tampa Tuning.
I am looking to throw in a beefy Cam (BTR stage 3 or Texas Speed equivalent) next year but want to install a torque converter first. Anyone have any recommendations, suggestions, feedback, timeslips on any of these? Currently thinking of one of the follwing:
3600 stall speed FTI: https://www.ebay.com/itm/28372250886...sAAOSwvwFeA4Ld
3600 stall speed Yank: https://www.texas-speed.com/p-6009-y...-corvette.aspx
3500-3600 stall speed Circle D: https://www.circledspecialties.com/6...o-series-245mm
(Anyone selling one?) Thanks in advance!!!!
Old Aug 4, 2021 | 04:04 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Circle-D . 258mm Pro Series C6 / 6L80E Billet Torque Converter
Single Disk Lock-Up
2,800-3,000 Stall
https://www.circledspecialties.com/6...o-series-258mm
Old Aug 4, 2021 | 10:38 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I am selling my YANK SS 3200 stall and the only reason that I pulled it out (just pulled it out today) is because of the California CARB SMOG law that will not allow us to have any tuning in our ECU's, so I had to go back to stock -I just went back to my stock Torque Converter and 2.56 rear due to the new California SMOG law, we cannot have anything tuned in the ECU, and that means not even having the YANK SS 3200 Stall and transmission tuned, not even the 3.42 Z06 rear differential that I had (pulled today as well). Which will be up for sale too.
Feel free to call or text me or email - it is in "MINT" condition and works flawlessly - I only have about 4,000 miles on it since I have owned it, no drag racing, or track time, just an occasional flogging here and there.
Thanks,Matt
661-406-7516
madmatt9471@gmail.com
Old Aug 5, 2021 | 01:43 AM
HOXXOH's Avatar
HOXXOH
When I had my 3600 Yank, about 1.56 60' times were the best. After I switched to a 4000 Yank, I ran 1.48 - 1.52 fairly consistent. '08 bolt-on w/2.56 gear. My racing buddy had a cammed '07, 4000 Yank, 3.42 gear, best 60' 1.51
Old Aug 5, 2021 | 08:16 AM
Turbo6TA's Avatar
Turbo6TA
What's wrong with installing a converter without the transmission tune tweeked ?
The Circle-D converter in my supercharged GS is working fine without transmission ECU changes.
My GS was dyno tuned after installing the supercharger ... However, later on, the converter was added, but no changes were made to the tune after installing the converter.
Old Aug 5, 2021 | 09:11 AM
madmatt9471
More than likely many of the parameters on your A6 were changed or adjusted when you were Dyno tuned -
When you go through the tuning processes for a Stalled Torque Converter you are able to take full advantage of it and ensure that you do not slip or do any damage to the trans - Stall converters are not plug-n-play unfortunately
Often times just throwing in a stall converter and not doing any tuning can make the trans throw a slipping code - ughh!
There are many tables that need to be adjusted and fine tuned for it to work properly and especially on a stock untouched transmission - you'd be surprised the difference after the fine tuning just how it feels!
Thanks,Matt
Old Aug 5, 2021 | 09:55 AM
Turbo6TA's Avatar
Turbo6TA
Thanks Matt,
Maybe I will bring my car back over to Redline Motorsports here in Florida and have Howard Tanner look at it and make some adjustments.
Howard initially dyno tuned the car after I installed the SC, but later, I had someone else install the converter and no re-tuning was done after that.
I have noticed that during normal city driving that it will upshift though the gears very quickly ... sooner than before the converter was installed.
At WOT, I get a lot of wheel spin when using stock rear tires, and as soon as the tires start spinning, it will shift to the next higher gear ... then it will shift back into the lower gear again when the wheel spin slows ... I think that is not real good for the transmission when it's happening at WOT.
Ron,
Old Aug 5, 2021 | 10:41 AM
Redline Motorsports's Avatar
Redline Motorsports
Thanks Matt,
Ron,
That's because the converter will shift MPH and RPM from stock. The trans controller references MPH to make part throttle shifts. Also there is more slip error then stock..
Old Aug 5, 2021 | 10:49 AM
Turbo6TA's Avatar
Turbo6TA
Thanks Howard ... Might need to make that drive over to Redline Motorsports, Pompano Beach from Cape Coral again
Old Aug 5, 2021 | 04:09 PM
Chokeu's Avatar
Chokeu
Thanks Matt for shipping that Yank out, can’t wait to have it installed!
Old Aug 5, 2021 | 04:19 PM
madmatt9471
You're very welcome -
I just sent you the HP Tuners tune file for a compare file to get things going for you
Thanks,Matt
Old Aug 5, 2021 | 07:14 PM
BadAV's Avatar
BadAV
That should be a really good converter for you. Not too low, and not too high, and it will give you a big kick in the pants when you stomp on the pedal and flash it.
To Which Torque Coverter?
