2007 Glitches
Old Sep 1, 2021 | 07:57 AM
Firstcoupe@67's Avatar
Firstcoupe@67
1st Gear
Default 2007 Glitches
Need some advise/assistance with:
1 rear view auto dimming feature has stopped but side mirrors still dim?
2 cruise control will not activate I have changed the fuse, brake fluid resevoir is full, brakes work, tail lights work?
3 where can I get updated navigation DVD?
Any thoughts from members
Old Sep 1, 2021 | 08:25 AM
Moved to C6 Tech.
Old Sep 1, 2021 | 03:05 PM
4SUMERZ's Avatar
4SUMERZ
1). Not a deal breaker for the rear view mirror. Mine darkens, but not significantly. If it's a real bother, buy a new one or used one.
2). Cruise will not work under the following circumstance. If the voltage is not showing. A wiring issue at one of the components needed to engage it. Clutch control switch, brake control switch, park brake switch, the multifunction stalk, etc. Service manual section added.
3). Latest and last Nav DVD update was version 10-2016
Ebay has them for about $10.00
File Type: pdf
Old Sep 2, 2021 | 08:34 PM
Long road's Avatar
Long road
3rd Gear
Thanks for the info and assistance
I will try to run a diagnostics on the electrical for the cruise control.
To 2007 Glitches
