X pipe weld in section for Z06 ??
Old Sep 10, 2021 | 02:51 PM
magnoman's Avatar
magnoman
Default X pipe weld in section for Z06 ??
Can't justify spending over $400 for corsa X pipe when can just get x pipe insert have Muff shop cut out H section weld in X pipe section for a 1/4 of the price .
Just can not seem to find the correct size x pipe section to buy ?
Has anyone done this / where to buy ?
Old Sep 11, 2021 | 07:24 AM
cdm747's Avatar
cdm747
St. Jude Donor '17-'18-'19-'20-'21-'22
Have the muffler shop get it, stock size for base is 2 1/2". I brought my C4 to a local muffler shop a few years ago and told them what I wanted. They had no problem getting the parts.
Old Sep 11, 2021 | 08:36 AM
labhound's Avatar
labhound
I thought about doing the same, then I came across a great deal on a Corsa axle back exhaust that's 3", so now I need a 3" cross over section.
Old Sep 11, 2021 | 10:34 AM
RetroGuy's Avatar
RetroGuy
Default Difference between stock H & new X pipe?
Anyone notice an improvement when replacing their stock H pipe with an X? Sound quality or performance changes?
Old Sep 11, 2021 | 10:46 AM
magnoman's Avatar
magnoman
I have B&B Bi- mode still some drone at highway speed and idle after Cam install want to try X pipe with B&Bs also have ZR1 cat back can try with x pipe
Old Sep 11, 2021 | 11:38 AM
grpweld's Avatar
grpweld
[QUOTE=magnoman;1604006706]Can't justify spending over $400 for corsa X pipe when can just get x pipe insert have Muff shop cut out H section weld in X pipe section for a 1/4 of the price .
Has anyone done this / where to buy ?[/QUOTe
Have you found one that has the same center to center dimensions as Z06 exhaust?
To X pipe weld in section for Z06 ??
