C6 tire sensors
Old Sep 18, 2021 | 09:56 AM
badgerdoc's Avatar
badgerdoc
Default C6 tire sensors
Replaced TPMS sensors on 2010 but the new ones are lighting up. Have reset them a couple of times problem still occurs.
Looking for any suggestions.
Old Sep 18, 2021 | 10:17 AM
RetroGuy's Avatar
RetroGuy
Tell us what brand you installed...
Old Sep 18, 2021 | 11:03 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
What was the part number was installed, might not be correct.
Old Sep 18, 2021 | 11:19 AM
badgerdoc's Avatar
badgerdoc
Brand: Mobiletron (amazon) TX-S024
All four replaced—the two rear ones working; the two front ones fail after about 20 minutes of driving
Old Sep 18, 2021 | 11:30 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
Looking at Amazon reviews they all say the same thing you are complaining.
Here is first complaint like yours:
September 13, 2021
Every couple of days one of the tires randomly loses its signal. It always comes back around ten minutes. I made the mistake of thinking higher cost was better but a cheaper brand I had purchased lasted through two tire replacements.
Old Sep 18, 2021 | 11:33 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
If you decide to return those sensors, or might want to bookmark these to links, I buy from them, never problem.
https://tpms247.com/collections/2005-chevrolet-corvette
https://www.tpms.com/default.asp
Old Sep 18, 2021 | 01:44 PM
badgerdoc's Avatar
badgerdoc
Thanks very much
Will check it out
Old Oct 28, 2021 | 12:21 PM
badgerdoc's Avatar
badgerdoc
I have replaced sensors with a set from one of the websites recommended. Now, after driving about 20-25 minutes, the two front sensors are failing. I have reset them several times, same results. I would welcome any suggestions for what I could do to get the system working. Thanks
Old Oct 28, 2021 | 12:50 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
I think it is time for you to get a set of original GM ACDelco TPMS sensors for your C6 and stop spending money on Chinese sensors that may or may not work all the time.
You need ACDelco # 20925924 for your year model 2010. . . . BTW, these are made in the UK
Amazon Amazon
Here is a great video showing you how to properly reset the TPMS sensors.
TPMS Sensor reset tool:
https://www.ebay.com/itm/23346216645...YAAOSwxwdfmpKa
Old Oct 28, 2021 | 01:39 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
For OEM sensors I'd recommend Forum Vendor Bob's House of Wheels.
Old Oct 28, 2021 | 03:00 PM
SG4247's Avatar
SG4247
I have two sets of wheels for my Z06, both with original GM/Delco 25758220 - 2008 MY TPMS sensors, that work perfectly.
13 years old and no issues! Lucky? Maybe...
The TPMS experts say the good TPMS sensors, have a battery life of 5-10 years.
Some recommend Schrader 20076. I am sticking with the GM part number.
Old Nov 19, 2021 | 06:40 AM
badgerdoc's Avatar
badgerdoc
I ave now replaced with OEM sensors and two of them are failing intermittently. I got a TPMS reading tool and it says these sensors are transmitting. I wonder if the problem might be the sensor monitor in the car and not the sensors. Have been looking online and it looks like the monitor (which is also the remote keyless entry module) is in the dash behind the radio. Is there any experience with this, suggestions, pearls? Thanks again.
Old Nov 19, 2021 | 10:03 AM
87SAM's Avatar
87SAM
I have not had the issue, but have read of some people blaming certain types of metal valve stem caps for sensor issues. Not sure of the validity of this.
To C6 tire sensors
