Radar Detector Mirror Wire Tap Issue
Old Sep 19, 2021 | 03:27 PM
Notover's Avatar
Notover
Default Radar Detector Mirror Wire Tap Issue
I've read all the info I can find regarding mirror wire taps and no where can I find how to connect and power a Uniden R7 into the powered mirror of a 2008 C6. I tried the RJ11 connector that's recommended and it will not power the R7. I used the black wire and pink (13) for the connections...no luck. The R7 uses 4 wires into the unit, not just the 2 that most use. I've search the web also and research shows it's the RJ11. Is it possible the inline 2 amp fuse is bad from the Chinese factory? Any thoughts from the experts?
Old Sep 19, 2021 | 06:40 PM
Notover's Avatar
Notover
Stupid me...the problem was the red pin not getting a good connection. Let the jokes begin...
