C6 2007 auto transmission.
Old Sep 27, 2021 | 06:56 PM
slysplace's Avatar
slysplace
4th Gear
Default C6 2007 auto transmission.
My 2007 C6 will not go into reverse or park. Plenty of battery power. Will not start since not in park.
Old Sep 27, 2021 | 07:03 PM
4SUMERZ's Avatar
4SUMERZ
The question that has to be asked is:
Is the shifter easy to move in all positions or
It moves but only in D and N
Old Sep 27, 2021 | 07:10 PM
4SUMERZ's Avatar
4SUMERZ
Welcome to the forum.
If it is the latter, then the park lock solenoid microswitch has failed, or not making good contact to energize the lock out solenoid to release the lock out pawl. You may have had to shift out of Park, but it was difficult, or the lock out pawl did not release fully, preventing the shifter from going back into park. This happens to many shifters due to that switch failure. Unfortunately, GM will not just replace the switch, but wants to sell the whole shifter assembly. That switch csn be purchased at an electronic store for a few $$
Old Sep 27, 2021 | 07:12 PM
4SUMERZ's Avatar
4SUMERZ
If it is the shifter moving freely, then one of the shifter cable end bushing has broken. Easy fix.
Old Sep 27, 2021 | 07:29 PM
slysplace's Avatar
slysplace
4th Gear
Shifter moves freely only in N & D.
Old Sep 27, 2021 | 07:31 PM
slysplace's Avatar
slysplace
4th Gear
slysplace's Avatar
slysplace
4th Gear
Old Sep 27, 2021 | 07:46 PM
4SUMERZ's Avatar
4SUMERZ
Here is the info for the fix in PDF format. Most of us have just tied the locking pawl back.
Good Luck. If you need the PDF for removing the console, I can add that as well.
To C6 2007 auto transmission.
