Harmonic Balancer on 2007
Old Sep 29, 2021 | 02:31 PM
DOOLS's Avatar
DOOLS
3rd Gear
Default Harmonic Balancer on 2007
Had to have this replaced 6 months ago. It's back at the dealer due to the new H.B. looking like it's going to fly off. I read that there was a technical bulletin issued back in the c6 era that warned of the H.B. bolt backing itself out. Does anyone know what Chevy's fix was for that? It makes me uneasy knowing that I only drove it 500 miles and it's back in the shop for this. Thanks in advance..
Old Sep 29, 2021 | 03:38 PM
torquetube's Avatar
torquetube
There are two separate unrelated problems with the harmonic balancer which are frequently confused:
1) The bolt loosens and the entire balancer assembly walks off the crank. This plagued early-production C6s and was addressed by the addition of a thin diamond-encrusted washer behind the balancer. The torque sequence is a pain and the factory TTY bolt cannot be reused. If your bolt came loose the most likely cause was improper installation.
2) The balancer itself comes apart, and the pulley section separates from the hub. The bolt remains tight. If this happened to you, the cause is a defective part.
Old Sep 29, 2021 | 08:52 PM
slowtealz28's Avatar
slowtealz28
I bet they either reused the original bolt, or didn’t use an ARP bolt. I wouldn’t let them touch it without a guarantee of at least a bolt that will keep it where it belongs.
Old Jul 18, 2023 | 01:53 PM
Speedy Silver's Avatar
Speedy Silver
1st Gear
Installed one over a year ago. Been using it to run an A&A supercharger. Have not had any issues. You might pin the crank while you're in there.
Old Jul 18, 2023 | 11:24 PM
C6 Motorsports's Avatar
C6 Motorsports
I bought a 06 Z51 with the harmonic balancer changed by the previous owner. After a hard day at the track, the bolt came lose and they used a stock flawed replacement balancer. SFI balancer is now installed with an ARP bolt to have peace of mind. Never use the oem junk balancers when changing them,
To Harmonic Balancer on 2007
