Maybe I’m having a brain fart but wouldn’t a +50mm offset stick out farther than +36? Reason I ask is I want to run C4 zr1 replica 17x11 wheels in the back of my C6z for track use only and every search says 36 offset is what I need to fill the fender. Next problem would be it seems no one sells these +36 style anywhere. Plenty of +50.
BTW ... I have a set of 17x11 rear wheels with drag radials mounted on them. The offset is +45mm
They don't stick out of the wheel wells, but are pretty close ... I would rather have a set of 17x11 rear wheels with an offset of maybe 48mm if I had the choice (to bring the wheel in just slightly more).
