Ecs blower + meth+ cam dyno...
Old Oct 18, 2021 | 09:55 PM
Snatchrick's Avatar
Snatchrick
Default Ecs blower + meth+ cam dyno...
Got my 06 at tk performance in ohii this week to get a trans and dyno tune. Taking guesses on final numbers... car has a ecs blower kit at 10psi, unknown healthy cam, alky control single nozzle meth kit, kooks long tubes, 3' x pipe and bb fusions. Ill be happy with 650 give or take. All through a tk built 6l80 with a precicion 2800 lockup converter.
Old Oct 19, 2021 | 11:05 PM
Omega Doom's Avatar
Omega Doom
650 on pump 93 and 705 with meth
Old Oct 20, 2021 | 05:44 AM
Snatchrick's Avatar
Snatchrick
Just maxxed the maf out so idk if it was setup for sd or what but it ran real good on the previous tune. Would pull on a modded cz7. He's converting it to a ls3 maf then back on the rollers. Hopefully i can get it back by this weekend
Old Oct 20, 2021 | 09:59 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Better off closed loop SD, you should make over 800 rwhp if the restrictor plate has been removed.
Old Oct 20, 2021 | 10:39 AM
Snatchrick's Avatar
Snatchrick
Ive always wondered which one is actually better... My last thought on the deal was maf is better for atmospheric/elevation changes. Im not sure what injectors are even in it ( i assume its the 60s) and probably stock fuel pump so im staying with the restrictor in for the time being.
Old Oct 20, 2021 | 04:05 PM
VVVROOMTX's Avatar
VVVROOMTX
800HP at that boost without E85? Doubtful.
Im gunna say with pumpgas + meth around 700
Old Oct 21, 2021 | 08:06 AM
DOUG @ ECS's Avatar
DOUG @ ECS
You do realize that I do this all day every day right?
Old Oct 25, 2021 | 04:34 PM
VVVROOMTX's Avatar
VVVROOMTX
Yes I do, I just haven't see really any cars, personally, make 800+ with the modifications listed. Pump gas + meth and 10psi through and Auto I would guess like low 700s.
Any videos of cars with same mods and auto?
Old Oct 25, 2021 | 04:40 PM
Snatchrick's Avatar
Snatchrick
I dont have the dyno sheet but he said it made 650ish spraying 100% m1 meth. Said its at the upper limit of my fuel system. Hopefully he sends me the graph soon so i can post it
Old Oct 26, 2021 | 10:23 AM
DOUG @ ECS's Avatar
DOUG @ ECS
There are literally hundreds of them out there, we have over 1,000 cars breaking into the 700's with those mods but we prefer an 8 rib direct drive by then. I finished a C5 last week that was 775 with those mods, it's very routine here.
Sounds right with the restrictor plate in place, enjoy!
Old Oct 26, 2021 | 11:15 AM
Snatchrick's Avatar
Snatchrick
The results are in....
Old Oct 26, 2021 | 11:23 AM
VVVROOMTX's Avatar
VVVROOMTX
What boost are those cars running? I only ask because in Houston, personally I've talked to and see about 20 different cars with almost the same exact mods as OP is stating, which are cam, blower, 93 + meth and auto trans, that make around 675-725 to the wheels. I'm at around 800rwhp with cam, blower, auto trans and E85 but at 12.5-13lbs of boost.
Even OPs numbers reflect what I'm thinking it should have made. I still don't think a cam + 1500 sized blower + 93/meth through an auto is going to net over 800hp on most occasions. Are the setups you claim make over 800 M6?
Old Oct 26, 2021 | 11:24 AM
VVVROOMTX's Avatar
VVVROOMTX
This was on 10lbs of boost correct? Can i get a full mods list?
Old Oct 26, 2021 | 05:20 PM
Snatchrick's Avatar
Snatchrick
Not knowing what cam is in there really bothers me. Im probably going to upgrade it eventually for a custom spec and do a fuel system so i can add a few more psi and shoot for 750ish. Im not trying to have to build a forged bottom end anytime within the next few years.
To Ecs blower + meth+ cam dyno...
