I have both the ARP and a new GM bolt, but decided not to use the ARP as I don't trust my old torque wrench is calibrated.
When installing the Gm bolt, after torquing to 37 ft lbs, I have to turn an additional 140 degrees. Must this be done in 1 movement (0-140), or can I do it in multiple movements (0-90 then 90-140)? The reason I ask is I don't think I'll have enough clearance to do it without repositioning the wrench.
Just put a mark at the 12 o'clock position (top) of the bolt head after torqueing to that initial 37 ft/lb since your going to be putting your breaker bar in different positions when making those baby steps to 140 degrees.
That's great news and is actually simpler than using the ARP bolt as I can use a long cheater bar.
I will mark the bolt, or just get one of the dial gauges for $10.
Just turn the bolt so the dot starts at the 12 o'clock (360 degree) position after that first 37 ft/lb torque is applied ... Then after tightening the rest of the way the dot ends when it's half way between the 90 degree and the 180 degree position.
One other thing .... If you [ever] plan on installing a supercharger on the engine, now is the time to pin the harmonic dampner to the crank ... Later down the road you will be damned glad you already pinned the crank.
