2011 horn dead
Old Oct 23, 2021 | 12:44 PM
71TTop's Avatar
71TTop
Default 2011 horn dead
Horn is dead, I have checked and changed fuse and bought new relay. Boy do I miss it with all the idiots on road.
Any ideas? How would I pull steering cover to check contacts?
Old Oct 23, 2021 | 01:54 PM
HK770's Avatar
HK770
https://www.corvetteforum.com/how-to...air-bag-368468
Old Oct 23, 2021 | 01:58 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
If the car is an automatic see if the paddles still work. If they don't then your clock spring is likely bad as it controls both those and the horn.
Old Oct 24, 2021 | 11:16 AM
71TTop's Avatar
71TTop
Yes car is auto and I tried paddles, even though I never used them, and they don't seem to do anything.
What is a clock spring and where?
Old Oct 24, 2021 | 04:11 PM
HK770's Avatar
HK770
https://www.google.com/search?q=c6+c...hrome&ie=UTF-8
https://www.corvetteforum.com/forums...ck-spring.html
Old Oct 24, 2021 | 04:47 PM
Rusler John's Avatar
Rusler John
I went through the same situation a few months ago on my 07'. Checked the relays and fuses, all OK.
So, I went under the front and checked the horn connectors. They looked OK but, I cleaned them and voila' that solved the problem. Now, everything is back to normal. I guess some moisture got into them and caused some corrosion that was easily fixed.
Old Oct 24, 2021 | 10:02 PM
Sunnyvale Dave's Avatar
Sunnyvale Dave
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'19
Did you have the transmission in sport mode when you checked the paddles? They only work in sport mode. The gear should appear on the HUD.
Old Oct 27, 2021 | 04:01 PM
71TTop's Avatar
71TTop
I put the shifter in S M and tried it, but didn't know about looking at HUD. I'll try again and see what happens.
Old Oct 27, 2021 | 04:17 PM
71TTop's Avatar
71TTop
Just tried it again. I felt no shifting of gears when in S M mode, on the HUD. My garage guy says there should definitely feel shifting up or down so this must be the problem. However, he says these springs are hard to find right now, OH goodie!
To 2011 horn dead
