Service Active Handling Traction System
Old Oct 26, 2021 | 10:35 AM
shelleygraham's Avatar
shelleygraham
Default Service Active Handling Traction System
I have a 2010 Grand Sport Convertible. I was going to put up the top and it said "set the parking brake". The brake was set. Also, the trunk bottom wouldn't work for the reason I put it in accessory mode and I was able to get the top up. I drive like 25 miles the DIC says, service the active handling traction system, and the symbol is lit. No codes came up only the service message. It goes away after I turn the car off but comes back after I drive. Also, when I'm driving I pull up the e brake and no chimes and no message In the DIC. I thought after research it might be the e brake limit switch. However, I called the dealer and their tech said it could be the switch or module or something to do with the power top mechanism not the e brake limit switch. Has anyone had this happen or know about this ? Thank you
